Old 16-02-12, 12:33 PM   #31
Paul the 6th
Paul the 6th's Avatar
Default Re: Highway code: Use the full amount of road space available
Originally Posted by punyXpress View Post
Rule 116 ?
Bet you rule the airport carousels, Paul!
Did a moon walk on one once.. got told off by the airport police people though
Old 16-02-12, 12:35 PM   #32
Paul the 6th
Originally Posted by Owenski View Post
I've said it before Paulo and I'll say it again, you worry too much.
When you put a hot drink in a flask, how does it know to keep it hot? How does it never ever get confused and think that you might want it to be kept cold?
How. does. it. know?
Old 16-02-12, 12:37 PM   #33
Owenski
Vacuum pal,
The vacuum is vacant, therefore none conductive. With no ability to conduct heat there is reduced heat loss and as such the content stays warm. If you were to fill it with a cold drink then you'd have the same effect inverted.
Old 16-02-12, 01:03 PM   #34
Ah ha actually dizzee I've got a lucrative scam going on with the old trolly/coin swap.
You walk up to a person taking their trolly back and say "oh are you putting that back?" they say yes, then you say "oh right well give us a quid and I'll take it off your hands"..
It's worked twice. One of the times was on the same day where I paid for a sandwich and crisps with a fiver and got change as if I'd paid with a tenner..
Priceless!
Old 16-02-12, 01:07 PM   #35
Paul the 6th
Vacuum pal,
But how does it know?
Old 16-02-12, 01:25 PM   #36
Originally Posted by Shay.Kelsey View Post
If you were halfway merged because someone let you in... You missing the point in this topic. It's about the idiots that dont let you back in, and if you pull into the path of one of these idiots I. The nearside accident then its your fault, end of. If someone drives into the back of you while your merging because they don't know what the duck their doing then they would have to be in the right hand lane because as you statedthe car in the left hand lane has allowed you in so that lane is now blocked.
If you were stationary and someone drove into your front corner I doubt it would be 100% your fault given that the slow moving car on the left could have stopped easily.
That is a really different kettle of fish to you saying "if you overtake traffic perfectly legally it is definitively your fault if you have an accident when merging"
Old 16-02-12, 01:27 PM   #37
Paul the 6th
Oil pump must have gone maybe?
Old 16-02-12, 01:28 PM   #38
Worse
Realised I have no rear view mirror to hang my fluffy dice on.
Old 16-02-12, 01:33 PM   #39
Paul the 6th
Oh shiit. Sorry mate. I was in the same position not so long ago. Just a metal stud on the windscreen where a mirror should have been.
Rang VW and they said £55. For a bit of glass and plastic. I was very upset.
Old 16-02-12, 01:36 PM   #40
Unfortunately mirrors don't stick on with gaffer either...... they fall off over night
What is this maneouver called - is it in the Highway Code ??? SoulKiss Idle Banter 28 02-06-08 02:45 PM
Highway code in e-format? ooger Bikes - Talk & Issues 11 25-04-08 08:21 PM
The New Highway Code mr.anderson Idle Banter 6 28-09-07 10:47 AM
The Pope's Highway Code Razor Idle Banter 9 22-06-07 09:38 AM
What would you add to the highway code? tigersaw Bikes - Talk & Issues 17 07-07-05 07:25 PM
