Old 05-04-12, 12:56 PM   #31
peeterus
Default Re: Debrix emulator curvy installation pictures
Originally Posted by flymo View Post
Why didn't you just wind in the adjuster to take up any slack first? Then add 2 1/2 turns as described?
i am referring to the soft, large, in the body contained, rebound oil release spring (excuse me if redundant).
if you calculate the area of maximun oil passage in the emu, it comes equal to two 9,5mm or four 7.5mm holes. In my gpz500, with 14mm or so rod inner diameter, had to use separator ring to have the 5mm clearance between the blocking nut in the downside of the emu and the inside of the damper rod top
Old 05-04-12, 05:14 PM   #32
Urbanfireblade
Originally Posted by 85jas View Post
5. Checking the height of the emulator (24mm) to see how much to take off the preload spacer.
That isn't 24mm as stated, its 14mm. Can't believe nobody else noticed!
Old 05-04-12, 08:38 PM   #33
Sy-superfly
My racetechs are 11.5mm just for info, I just thought the cheaper ones were bigger.
Old 05-04-12, 11:27 PM   #34
hongman
I didn't cut my spacers down either but left the preload on fully unwound. Not had a chance to test it yet.
Also not yet got round to checking sag, must get round to doing that.
I sooo want to sort the back end out
Old 07-04-12, 12:08 PM   #35
85jas
Haha!!! So it is... duly edited. lol.
+1,000,000
Debrix Cheap Emulator Group Buy. Epic Monkey SV Talk, Tuning & Tweaking 80 22-03-13 11:40 AM
Debrix Cheap Emulator Group Buy Take 2 Dipper SV Talk, Tuning & Tweaking 164 02-04-12 11:50 PM
Debrix Cheap Emulator Group Buy Take 3 takracing SV Talk, Tuning & Tweaking 7 17-03-12 12:30 PM
Debrix damping emulator questions bigchris SV Talk, Tuning & Tweaking 13 13-07-11 02:08 PM
Inforad installation advice for curvy SV Lucas SV Talk, Tuning & Tweaking 21 18-03-09 11:06 AM
