Old 18-04-12, 03:15 PM   #31
Default Re: Potential pointy Adjuster Plates Group Buy
the reason for the downstand for the oilier is so it moves the nib with the wheel so keeping it in the perfect position on the sprocket each time you adjust the chain. another benefit is that you move the nib out the way when taking the wheel off which again stops you having to mess about setting the nib up again when you fit the wheel back on.
Old 18-04-12, 03:16 PM   #32
i'll check see if there is any 3mm SS at the workshop first. i would like to get the pointy ones sorted first. but yes i would require the plates to have a look as i found with the pointy ones there is a few things needed to remove the 'slop' and fit properly on the spindle.
No worries, sort out the Pointy's first
Old 18-04-12, 03:21 PM   #33
garynortheast
garynortheast's Avatar
I'd certainly be interested in a set with the scottoiler bit for my curvy, if you feel so inclined to sort some once the pointy ones are dealt with Bibio.
Old 18-04-12, 03:36 PM   #34
joshwalker094
joshwalker094's Avatar
I'd be happy to do the bulk postage thing with Nobbylad
1..joshwalker094....non-scottoiler, with hole
2..DarrenSV650S.....
3..Epic Monkey......
4..MJC-DEV..........
5..Nobbylad.........
6..muzikill.........
7..The Guru.........Non-Scottoiler
8..The Guru.........Non-Scottoiler
9.. fluffer
10.Kilted Ginger
11. Turner
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 18-04-12, 04:14 PM   #35
MJC-DEV
MJC-DEV's Avatar
Small update
4..MJC-DEV..........non-scotoiler
9.. fluffer
10.Kilted Ginger
11. Turner
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 18-04-12, 04:49 PM   #36
Jayneflakes
Jayneflakes's Avatar
Originally Posted by MJC-DEV View Post
Small update
9.. fluffer
10.Kilted Ginger
11. Turner
12. Jayneflakes, but with a simple question.
Will it be compatible with my Tutoro oiler?
I assume that the K3 arm is the same dimensions as the others? Would look well Bling on my sexy little girly bike.
Jayne you're a Pussy Magnet
Old 18-04-12, 04:55 PM   #37
twinset
I will take a pair, if i may, non Scottoiler. these really would be an improvement.
twinset
Old 18-04-12, 05:38 PM   #38
Davy.h
I would also very much like a pair,great idea.
Old 18-04-12, 05:40 PM   #39
muzikill
muzikill's Avatar
My thought exactly ..... If it can use a tutoro its a quality addon.
Old 18-04-12, 05:46 PM   #40
Speedy
I'll have a pair, NON-OILER type please!!
Very nice!!
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
