#31 |
I'd have insisted on having a lock in the outside of his door! Wouldn't want him laying in wait for me to need the bathroom... Stealth attack with the cover of darkness on his side.
#32 |
Which engine cover is that? I suspect it's the ignition rotor/pickup. If yes, then the engine turning hex is under there on the ignition rotor, and as such the cover will need removing when the bike is serviced to turn the engine when setting the valve clearances, it's probably not had the gasket replaced and thus weeps a bit.
That's if it's the cover I think it is anyway. Unless it's weeing out it's unsightly rather than problematic. The gasket is easy to replace if you're concerned about it.
Oil Leak, Need advice | Serdna | SV Talk, Tuning & Tweaking | 9 | 24-08-11 06:17 PM |
brake fluid leak advice please | jimc | SV Talk, Tuning & Tweaking | 4 | 27-02-11 03:09 PM |
advice needed RE caliper leak. | arcdef | SV Talk, Tuning & Tweaking | 11 | 31-01-09 04:56 PM |
Oil leak, garage at fault?? advice needed | DeanoN | SV Talk, Tuning & Tweaking | 7 | 13-01-09 05:54 PM |
Petrol leak update advice please | Quiff Wichard | SV Talk, Tuning & Tweaking | 8 | 09-02-06 01:19 PM |
