#31 |
Let's hope it will be ok
![]() Sent from my GT-I9505 using Tapatalk |
#32 |
charged the battery put it on the bike and it was up and running once again
#33 |
Lesson learnt always check your fluids...glad it's ok thought mate
#34 |
yep
#35 |
You lucky barsteward
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Crash.NET - Laverty eager to seize Laguna opportunity | NewsBot | News | 0 | 19-07-13 06:00 PM |
Crash.NET - Upbeat Laverty vows to seize MotoGP chance | NewsBot | News | 0 | 11-12-12 10:00 AM |
Caliper seize! | Moojuicepez | Bikes - Talk & Issues | 21 | 08-03-10 10:09 PM |
Google street view - seize the moment! | rob13 | Idle Banter | 18 | 11-07-09 08:21 AM |
Anti-seize on bolts? | doser | SV Talk, Tuning & Tweaking | 5 | 11-04-09 10:17 AM |
