#31 |
Check the routing of the cables as well, as it shouldn't do that
#32 |
Yeah it's odd, noticed it last week. Is there a wiring diagram of where it should go, so I can compare?
#33 |
Update, took the bike to my local bike garage in passing.
He says that there is usually quite a few vibrations/buzz around 6k rpm onward and that it is the nature of Vtwins. He also said it is running as sweet as a nut! Basically he had a listen for anything on toward gave it a few revs and said it sounds and feels exactly the same as another SV they currently are doing work on. |
#34 |
If it was crank, or anything knocking (Upper of lower) you would hear it. We have a Renault with big ends going so know what it sounds like.
The bikes pulls fine, and after the oil/filter and plug change it runs so much better. Maybe it didn't notice, but the vibes are from 6k onwards - getting more as the rpms increase. 5k and below I don't really notice, in 1st at 3k there is a little bit more, but it evens out. The chain does need adjusting though. Does that sound about right? I'm, a bit of a whittler! |
#35 |
I was going to say check your rear chain adjustment/alignment. I built a bike with a misalignment of 1/16" and it vibed like a bugger but after shimming was super smooth.
#36 |
I'm going to give it a check tomorrow Blapper.
![]() Other than that, does all of the above stuff sound about right to you? |
#37 |
As the bike still vibrates when stationary the rear chain etc are red herrings, I would suspect ignition / spark plugs - especially as you say it does not want to start easily.
#38 |
I replaced all the sparkplugs and made sure they where in properly. The bike starts on the button every time now!
The starting issues where because of the battery. ![]() |
Pointy, sudden loss of power | JLeo | SV Talk, Tuning & Tweaking | 1 | 10-06-14 12:22 PM |
Sudden increase in fuel consumption | rowdy | SV Talk, Tuning & Tweaking | 8 | 11-11-10 04:47 PM |
sudden highish idle? | svscratcha | SV Talk, Tuning & Tweaking | 3 | 05-08-08 09:55 PM |
sudden loss of power | Ben Flanagan | SV Talk, Tuning & Tweaking | 11 | 22-04-08 12:59 PM |
Sudden Increase in throttle | Grinch | SV Talk, Tuning & Tweaking | 4 | 01-10-07 01:59 PM |
