Old 06-01-17, 04:23 PM   #31
Blapper
Blapper's Avatar
Default Re: Front brake caliper overhaul...
fronts yes, rear no.
Thanks Bibio.
Originally Posted by Craig380 View Post
By the way, are the standard factory-supplied caliper pistons made of stainless steel?
The material looked like stainless when I last gave the calipers a clean & grease ...
I've just replaced a piston due to having a rush of blood to the head and using grips on it to get it out as compressed air wouldn't. I got the replacement from Wemoto is stainless, the originals are plated. The originals have a lovely radius on which makes inserting them easy, the Wemoto ones only have a sharp chamfer so requires care.
Old 06-01-17, 04:47 PM   #32
bit late now but if you take the callipers off and leave the pads in then pump the front brake lever it pushes the pistons out for you
Old 06-01-17, 05:18 PM   #33
Craig380
Interesting, ta for that. The caliper pistons on my old 70s Suzi stroker were chrome plated (and badly pitted when I changed them), but the SV ones on mine have that dull, yellowy appearance which made me think they might be stainless.
Old 07-01-17, 12:58 PM   #34
Blapper
Blapper's Avatar
bit late now but if you take the calipers off and leave the pads in then pump the front brake lever it pushes the pistons out for you
Aye Bibio, I was annoyed with myself for doing that and straight away formulated a system to free seized pistons (not that they will seize again ).
Old 07-01-17, 10:59 PM   #35
nutzboutbikes
its amazing the amount of wrong advice people are given on such places as youtube but take as gospel due to not knowing any better.
Old 08-01-17, 09:38 AM   #36
SV650rules
Originally Posted by nutzboutbikes View Post
The internet is full of rubbish, biased opinions and untruths, but just like a heap of dirt it is possible to find diamonds in there, but you have to have a certain level of knowledge in the first place to know a diamond when you see it.
2016 SV650 AL7
Old 08-01-17, 12:29 PM   #37
Blapper
Blapper's Avatar
True. Also true (but less often realised) is that you can find any answer you want to a question if you keep looking...
Front brake overhaul Benjins SV Talk, Tuning & Tweaking 12 10-10-16 10:48 AM
Brake Caliper Overhaul - Bit of a How To SV_archie99 SV Talk, Tuning & Tweaking 14 20-11-14 10:01 PM
Brake caliper overhaul muzikill SV Talk, Tuning & Tweaking 51 18-06-13 08:51 AM
Front brake caliper overhaul. Danny Dickinson SV Talk, Tuning & Tweaking 24 31-08-12 11:16 AM
Front caliper seals/overhaul `99 curvy leebex SV Talk, Tuning & Tweaking 14 04-02-10 11:06 AM
