Old 12-08-19, 07:52 PM   #31
Adam Ef
Adam Ef's Avatar
Default Re: Installing YSS emulators on Curvy
Someone wil have them on eBay I'm sure. They fit quite a few bikes.
Past:
Old 18-08-19, 10:32 PM   #32
my advice for what its worth.. dont bother with emulators unless you want to spend a fair amount of time ****ing about getting the "pop" right.
1. get the proper springs.
2. weld the rebound holes up.
3. use silkolene RSF10w.
4. ride it like you stole it.
its that fukin simple.
Old 28-08-19, 07:07 AM   #33
JaxintheUK
Junior Member
Yep, I'm starting to think getting new springs is the way to go. 10w oil feels so much better and stiffer than 7.5, just a bit bumpier. Closing up the rebound holes without emus? What will that do to the suspension? Won't it feel a bit juddery? Why are they there? Still learning about suspension setups, so please excuse all my questions.
JaxintheUK is offline   Reply With Quote
Old 28-08-19, 07:49 AM   #34
aesmith
New suitable springs should be the starting point. If you don't have access to a welder you can block the rebound holes with epoxy. On that point I understand that the SV rebound is mainly "controlled" by leakage between the fork tube and the damper rod, where it says "Check valve passage" in this diagram https://racetech.com/HTML_FILES/DampingRodForks.HTML
Old 28-08-19, 07:04 PM   #35
Adam Ef
Adam Ef's Avatar
Yep. Most of the fluid leaks through where it's not meant to rather than the rebound holes. Weld them up to get it under control a bit more. Springs for your weight and oil for the compression speed that you want. Air gap can make quite a difference to plushness too.
I did the emulators and I think it took me about four or five times messing with oil and removing them and adusting them before I got near what I was really happy with. That process lasted a couple of months. I'd say most of the effect came from the new springs and oil though.
Past:
Old 29-08-19, 10:00 AM   #36
aesmith
Out of interest what was you're process for tuning the emulators? I mean for deciding which way to adjust them. I'm not sure whether to start with them fully backed off then increase the preload until it reduces dive on the brakes. Or go the other way, start with them cranked right up then if that's too harsh try them a little softer. I'm currently on two turns of preload by the way.
Old 29-08-19, 10:49 AM   #37
Adam Ef
Adam Ef's Avatar
I think I read a guide somewhere that said they recommend 2 and half turns in as a good starting point. It took me a while to work out where that started from though. With them turned all the way out or just taking up the slack so that the bolts are just starting to move the discs? I think I went with the latter and found them slightly harsh. But I was mixing different oil in each time I did it. I think in the end I ended up with equivalent of 12.5wt, which is starting to get heavy (esp with the Silkolene RSF I used as that it quite a heavy one anyway .. no two brands are the same no matter what number they put on the bottle). The heavier oil would have been affecting the emulators a bit so I think I ended up with them 1.5 turns in and that weight of oil gave me good controlled rebound too. No pogoing when the suspension bounced back up.
The guy I sold my bike too was blissfully unaware of what I was talking about when I told him I'd done all this. He probably thinks that SVs handle like mine did as standard. I put weeks of work into it though. I did enjoy it though, sort of..
Past:
Old 29-08-19, 09:36 PM   #38
johnnyrod
johnnyrod's Avatar
The number of turns is from when the springs are just seated. They are quite soft springs so you have to pay attention to finding that point otherwise you'll end up with the two emus set differently.
Wanted curvy emulators Joe Marcon Stuff Wanted 6 29-04-12 08:37 AM
Emulators fitted - Curvy. garynortheast SV Talk, Tuning & Tweaking 20 17-04-12 02:41 PM
Cheap knock-off curvy emulators? jambo Soho Massive 19 21-07-11 08:12 PM
Cheap curvy emulators Spoon For Sale - SV's and SV related items 7 28-06-11 03:25 PM
Curvy Emulators brand new 7755matt For Sale - SV's and SV related items 14 26-05-10 02:28 PM
