Old 19-05-06, 09:57 PM   #31
Khewett
Originally Posted by JMG
I think thats an SRAD wheel, the k1> wheels have diamond shaped spokes.
Boll%&ks was thinking as much!
In this case will it fit better using a SRAD axle?
Old 19-05-06, 10:01 PM   #32
JMG
Wait there, i'll just go and measure mine
Old 19-05-06, 10:08 PM   #33
Khewett
you star
Old 19-05-06, 10:09 PM   #34
JMG
Don't know if that'll help?
Old 19-05-06, 10:21 PM   #35
Khewett
helps a lot mate
My axle nut is also 57 but the spacing between the spacers when its fitted in with both ends flush (no wheel) is about 127- 128mm.
Therefore as I must have a SARD wheel if I get a SARD axle I should have the same measurments as you belowand thus me wheel will fit????
Old 19-05-06, 10:26 PM   #36
He's right you know. Quite embarrassed I didn't notice that, I've been viewing this thread with increasing confusion
I've often seen it said on SV Rider that there's no danger from simply centring the wheel and tightening the pinch bolts with the axle sticking out at either end. I wouldn't do it, myself, but thought that might be worth mentioning.
Old 19-05-06, 10:31 PM   #37
Khewett
So a SRAD axle and the same nut should sort my issue with the axle??
May have to stick a washer behind the calipers to space them a few mm from reading elsewhere.
Old 19-05-06, 10:33 PM   #38
JMG
IIRC the axle nut is the same for SRAD and K1> so the spacing will be the same whichever you use. I think i'd go for getting the axle turned down to fit as posted earlier.
Old 19-05-06, 10:34 PM   #39
Would getting the right wheel not be the fix? I know, not exactly cheap or quick but seems like it's only the hub width that's giving you problems.
Old 19-05-06, 10:36 PM   #40
Khewett
Would getting a SRAD axle not be the easist method rather than a new wheel, now the wheel is the right colour , etc???? Nothing else should be affected?
Looking at measurments above the axle should give me the extra width to accomadate the wider hub?
GSXR 750 k4 front wheel axle part. Caddy2000 Idle Banter 4 22-12-08 10:56 AM
GSXR front end insurance question crashers SV Talk, Tuning & Tweaking 9 07-02-08 06:39 PM
Project GSXR front end - FITTED WITH PICS PAGE 2 -56K BEWARE Khewett SV Talk, Tuning & Tweaking 32 05-06-06 09:25 AM
Another GSXR front end question - ignnition Khewett SV Talk, Tuning & Tweaking 14 19-05-06 07:29 PM
Ye olde GSXR front end question... Brand New SV Talk, Tuning & Tweaking 5 01-07-05 03:40 PM
