#31 |
that should be relatively easy - I would offer you my clipons, but mine are bent from the crash.... the only problem I could forsee would be that the cables are a bit long (prob not an issue) or that the steering lock might be different (clip-ons fouling tank??) but the more knowledgeable members should be able to clear that up!
#32 | |
I think the lockstops are the same on both models. If you're using the clip-on's ignore my stuff about control cable swapover, no need.
I'd get a small bar-end mirror, they mostly have a convex lens and give a great view, even better than the standard ones. You can see behind you in your own lane too, without adjusting your position, and your elbows are not in the way. ![]() Quote:
![]() Try removing your key whilst in the ON position. ![]() The barrel is bolted to the steering damper bracket. The only thing I've lost is the steering lock, but that bothers me not. |
#33 | |
MT |
#34 | |
USD Fork Conversion. | SV-net | SV Talk, Tuning & Tweaking | 2 | 05-02-08 01:14 AM |
m4a - mp3 conversion | embee | Idle Banter | 17 | 04-06-07 09:22 AM |
700 cc conversion | CHICKENSTRIPS | SV Talk, Tuning & Tweaking | 23 | 30-08-06 02:56 PM |
Better light with HID Conversion Kit? | zunkus | SV Talk, Tuning & Tweaking | 13 | 18-08-05 06:10 PM |
which air box conversion? | Londonoz | Exhausts | 2 | 20-01-05 02:43 PM |
