Old 30-07-06, 06:39 PM   #31
Blue_SV650S
ta-daaaaaa!!!!!!!!!
Temp gauge to lower right of clocks, fitted and working!
who is your daddy???
You can see the fan switch I mounted on the front of the yoke too
Old 30-07-06, 06:57 PM   #32
21QUEST
21QUEST's Avatar
Looks well neat and tidy . One could almost miss it.
..and for your next trick?
Ben
Nemo me impune lacessit.
Old 30-07-06, 06:59 PM   #33
BILLY
Ben
A fuel gauge
Old 30-07-06, 07:14 PM   #34
Blue_SV650S
I am going to mount a thumb operated laptimer using the horn switch as the trigger
Donor laptimer from Maplin for £6:- http://www.maplin.co.uk/Module.aspx?...timer&doy=30m7
After taking apart and soldering some wires to the button terminals so I can connect a remote button … and we end up with this …
Ready to connect the other end of the wires to the horn button
Oh and this is what it was all for!! … My SV trackbike, which I will be using for the first time ever at Lydden on the 5th Aug
Old 30-07-06, 07:14 PM   #35
Speedy
Originally Posted by andyaikido
Mines 84 -87. (pointy)
Ditto.
Old 30-07-06, 07:23 PM   #36
21QUEST
21QUEST's Avatar
Now , you are getting to being the daddy .
....so what you going to raise us next.
Ben
Old 30-07-06, 07:44 PM   #37
Blue_SV650S
Ben
Cor … you don’t want much do you!!
I got my all-in-one onboard camcorder … that I need to fit … … you may have read my post about my trials with it?! I have actually now chopped into that and wired it up such that I can have a external battery pack … for two reasons … I think that it might take some of the vibration away if I can locate the heavy batts outside, also I can use AA batteries instead of the internal AAA, this should give me more durability. I also have loads of AAs!!
That do ya???
Anything else you want me to hack apart?!?!?
Old 30-07-06, 07:58 PM   #38
21QUEST
21QUEST's Avatar
Oh Jeez no, that'll do for now .
It's like 'how long is the warranty?'
For everyone one else 2 years and for Blue_ , once he is out of the door :P .
Good work though.
Ben
Old 31-07-06, 01:00 PM   #39
Blue_SV650S
Good work though.
Ben
As a tip, never lend me anything .. unless you want it back in bits or modified!!
Old 31-07-06, 03:12 PM   #40
petevtwin650
Temp gauge looks good, but how does it read Blue? And will it be waterproof?Think I'm going to be fitting one of these next as the sender for the fan switch is 50quid I believe and the gauge a lot less.
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
