Originally Posted by Viney
Originally Posted by hovi5
Originally Posted by alpinestarhero
WHat heated grips you getting hovi5? how much are they? I wanna fit some to my SV aswell. Will it drain the battery much?
Matt
looking into hot grips.
they look simple to fit.....the only problm is, there is a switch to turn then on/off which you put somwhere. if you leave them on & take the key out they will still be on so flat battery in the morning
please correct me if im wrong/ or how to avoid this
Take it to a dealer. You cant even do something simple like making WMP look for files
Just get a std set of grips. Dont pay anymore than £30 and make sure that you install a realy that will turn them off with the ignition.
Gad sir! I like the cut of your jib!! (and relay)...
