Old 12-06-07, 04:53 PM   #31
danf1234
Default Re: stebel magnum ?
I have got a stebel on mine and I couldn't be arsed fitting a relay. The horns not fried itself either yet and it has had plenty of use of York's mareish bypass.
Old 12-06-07, 05:00 PM   #32
Baph
post up a shopping list of what i will need then.....please
Another one with a shopping list? Blimey!
Lets see:
Relay, wire (1m is probably about right, has to be able to handle the current of the magnum), male & female insulated spades, magnum horn, wire cutter/stripper. Tools to lift tank. You also need to think about where you'll mount it on the curvy, as I have no idea. Any mount you need for that plus fixings. That should be your lot.
Where's best to mount these little beauties. What's likely to sound best; 1 magnum; 1 magnum + standard; 2 magnum or 2 magnum + standard?
Regards
On my pointy, both are mounted on the top bolt of the radiator protector cover thingies (technical term). 1 magnum is rated at 139dBA, I forget what the stock meeper is rated at, but as said above, 1 magnum is more than enough. I have 2 magnums, and I'm looking at something like the Stebel HF80/1 to compliment these (same frequency as the stock meeper, with more volume).
The "beats" thing involving 1 (or more) magnum(s) is just a neat way to grab some serious attention. You'll probably need to hear it to appreciate it, and then decide if it's for you or not. At the moment, I only have 2 magnums, so I don't have the "beats" setup.
That's all well and good, but that's not the general rule of thumb. I'd rather spend £2 on a relay, than have to buy a new loom because it melted.
Old 12-06-07, 06:04 PM   #33
phil24_7
Another quicky. Magnum or Naultilus???
Oh, and has anyone got a sound clip of the "beats" setup?
Old 12-06-07, 10:35 PM   #34
hovis
Lets see:
so what wire do i ask for ?
Old 12-06-07, 11:08 PM   #35
dirtydog
Knob faced knobster
dirtydog's Avatar
Mine is wired in using a little 15A 12v wire (Maplin again).
Do pay attention hovis
2011 Speed Triple 1050
Old 12-06-07, 11:33 PM   #36
Luckypants
Luckypants's Avatar
That is where my Fiamms were mounted on the curvey, you need to bend the mounting bracket into a kind of 'S' shape so they don't foul the fairing. I use mole grips to bend em.
Old 22-06-07, 09:42 AM   #37
hovis
just got mine off ebay (brand new) with a grand saving of £5.50. just checked it on a spare battery........... $h1t its loud, its a low tone one.
still need to get to maplins though, for the bits & pieces.
if it was the case of just repacing the old one easy, but im going with the relay option, so going to get it done on the AE where i will have supervision
Old 22-06-07, 09:46 AM   #38
Baph
Mines louder than yours
Stebel Magnum Horn Stradders SV Talk, Tuning & Tweaking 5 20-10-08 07:49 AM
Stebel Magnum horn - fitting Tigerrrr....... SV Talk, Tuning & Tweaking 3 23-09-06 09:45 PM
Magnum Hi Leg boots Ed Boots 0 08-06-06 08:20 PM
Stebel Magnum horn bendelfont SV Talk, Tuning & Tweaking 5 11-07-05 09:08 PM
