Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
18-06-07, 03:20 PM | #31 |
Re: computer help again?
yea still does boot different but shes coming on ok, windows seems to be assisting with the boot up? i'll reboot and see if i can write down what its saying.
18-06-07, 03:26 PM | #32 |
right'y'o -
CMOS checksum error - defaults loaded IDE scan 1 not detected 2 not detected 3 not detected 4 not detected enter setup press F4 to enter raid utility press S to carry on with boot up. if you do nothing it just boots up on its own without touching anything or pressing S. |
18-06-07, 03:54 PM | #33 |
That there is caused by a flat battery. The computer restores to defaults every time it gets power, but that doesn't do anything with the old checksum, which is why the checksum mismatch happens (the checksum is for the original BIOS settings, the BIOS is on factory default settings, not the original ones).
You need to know the boot order as defined by the jumper settings & cable positions & then set the boot order in the BIOS, then hit save, and that will update the checksum and all will be quiet then on boot. |
18-06-07, 04:00 PM | #34 |
the only boot sequece i mess with is the hdd, cd rom, floppy in bios?
ive got it on floppy, cd rom, hdd. |
18-06-07, 04:05 PM | #35 |
You will have an area in BIOS that allows you to configure hard drives (capacity, number of heads per cylinder, number of tracks etc etc). This is usually a table, and I'd bet a scottish pound that yours is set to "Auto detect" for all four IDE drives.
Set all to disabled, error goes away. You'll be using a different drive type (SATA or RAID possibly) for boot, and won't be using the IDE channels. |
18-06-07, 07:00 PM | #36 |
cheers baph your a star!
18-06-07, 07:24 PM | #37 |
BAPH HELP
my bios screen looks like this but i dont know where to find what your explaining? standard cmos features, frequency voltage advanced bios features, load failsafe defaults advanced chip set features, load optimized defaults integrated peripherals power management setup pmp/pci configs pc health status and idea which one of these it would be in? |
computer help!! | malks | Idle Banter | 13 | 21-10-08 08:02 PM |
Computer help | 600+ | Idle Banter | 16 | 16-07-08 09:40 AM |
Computer Help... | poisonidea | Idle Banter | 4 | 10-01-07 01:40 PM |
what does your computer do? | hovis | Idle Banter | 38 | 08-01-07 11:53 PM |
More computer help... | JediGoat | Idle Banter | 1 | 17-09-06 01:24 PM |
