03-03-08, 01:44 PM | #471 |
Re: Silverstone GP - Mon 31 March
With a month to go, you might want to leave the final check until a bit nearer the time ... like the night before ... presuming you are going to use the bike between now and then, there is no point doing your pre-trackday check now
03-03-08, 03:58 PM | #472 |
I have a horrible feeling work aren't going to give me the day off......
03-03-08, 04:02 PM | #473 |
03-03-08, 04:02 PM | #474 |
03-03-08, 05:00 PM | #475 |
03-03-08, 05:04 PM | #476 |
03-03-08, 05:11 PM | #477 |
03-03-08, 05:59 PM | #478 |
I need to get some practice in. I've only done 100+ miles once this year and by the end my clutch wrist was aching as were my thighs due to continually hanging off the bike.
03-03-08, 06:05 PM | #479 |
03-03-08, 07:16 PM | #480 | |
Just loosen the rear wheel spindle nut a little way and then take the 12mm spanner and turn the adjuster nuts a quarter turn at a time each clockwise until the slack is correct. If you start on the left nut, end on the right, do both the same amount of 1/4 turns to keep the wheel in line. Once it's got th right slack you tighten the spindle nut. So simple a blind chimp could do it. I'm bringing a toolchest to Silverstone, so if anyone wants chains adjusting on the day, don't be afraid to ask. |
Silverstone GP - 9th march - £99 | chris8886 | Track Days | 0 | 03-03-09 11:32 PM |
Silverstone Nat. Sun 1st March 2009 | phil24_7 | Track Days | 29 | 03-03-09 08:55 PM |
I'm only going to Silverstone again | monkey | Soho Massive | 25 | 30-04-08 04:03 PM |
others @ silverstone | rictus01 | Photos | 3 | 12-04-08 10:23 PM |
Silverstone ? | stewboy | Idle Banter | 36 | 28-05-06 07:23 AM |
