14-08-20, 08:22 PM | #41 |
Re: Gen1 battery woes again!
I had to do a bit of bolt swapping too with the rr85, just a real shame mine turned out to be a lemon.
15-08-20, 02:48 PM | #42 |
It has a big red notice on my Electrex RR851 that it should not be used with Lithium Ion batteriy..... I have read that the charging requirements of Li-ion are a lot different to lead acid AGM, Gell and flooded batteries ( and even gel although still lead acid need a higher voltage than AGM / flooded ). I have also read that many have bought a Li-ion battery for a bike and had it fail in a short period ( and they are not cheap ). Battery sellers should warn potential buyers that they probably need to change their RR to a Li-ion friendly type - and they must get plenty back under warranty, is that when they say ' did you change your RR - if not the warranty is void' ?
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 15-08-20 at 02:49 PM. |
15-08-20, 03:00 PM | #43 |
I just used a standard gel battery, the rr85 was dead on two of the tests, pretty sure I was ripped off by the seller tbh.
15-08-20, 06:02 PM | #44 |
I'm using 3 Shido LiFePO batteries, one has been in the NC700 for about 3 yrs now. I've had absolutely no issues with them, all on FH*** type reg/recs.
It might be more of an indictment of the Electrex r/r than of the LiFePO batteries. Shido make no mention of checking or changing the r/r, as far as their blurb goes it's plug and play in standard production bikes. Perhaps earlier Li-ion batteries didn't have the onboard regulation that today's versions have? They have tech stuff available online giving charging requirements. It is not strictly true that you can't use a "normal" charger with them, what they mustn't experience is de-sulphation cycles which some chargers can apply. I charged my first one with a regular charger and monitored the voltage as it reached near full charge to avoid over-voltage. Acceptable voltage/charge curves are readily found if you search. I have since invested in a Li-ion charger.
15-08-20, 07:36 PM | #45 |
Ok, thought I would post findings on my Electrex rr85 just to be sure it's not operating as it should.
1/ fully charged battery ...13.10v 2/idle, no lights ...14.02v 3/ idle, lights on full beam ...12.35v and slight lumpy tickover/ misfiring slightly. 4/ 5000rpm, no lights ...13.96v. 5/ 5000rpm lights on full beam ..12.59v. 6/ reg rec temperature after 10 minutes ... 48°c. 7/ engine off, battery still connected ...13.14. Then after 10 mins ...13.09, then 10 more mins ...13.04, then 10 mins ...13.01. 8/ stator each wire 75v@ 5000rpm, rises and falls with throttle position as expected. I haven't put my new FH022BA rectifier in yet, just wanted to be sure it's the rr85 that's knackered. Can I assume from the figures above that the rr85 is not in good health or are there more checks I could try/do? Thanks peeps. |
15-08-20, 09:28 PM | #46 |
You should be getting 14.4 to 14.7 volts out of RR for a AGM or flooded battery, the 'float' voltage to keep a battery as is without really charging it is 13.6 to 13.8v, and you need more than those voltages with a gel battery. The Electrex RR851 on my SV is 14.5 at tickover and bang on 14.6 throughout rev range..
15-08-20, 10:32 PM | #47 |
Agree with SV650 above.
16-08-20, 06:06 AM | #48 |
Thanks for the confirmation, just making 100% sure the r/r is dead before I change it.
24-08-20, 05:58 PM | #49 |
Simply cannot believe how cool the electrex RR851 on my AL7 runs, went out today and checked heatsink temp a few times with my fingers, also let bike run stationary in garage when I got back... could not hold my fingers on the shindegen original shunt RR as it ran at over 70deg C. - could easily hold fingers on the electrex it felt no more than 40 degrees. Will try to measure stator and charging current when I get my fancy ac / dc current meter... the big benefits of a series RR are that both the heatsink and stator run a lot cooler.. dc voltage also very stable across rev range. 14.5 at tickover and 14.6 at anything above that...
25-08-20, 12:27 PM | #50 |
Instead of present situation where I wired my digital voltmeter to front sidelight I may have to wire it back direct to battery as due to size of cables and various plugs and sockets in the wiring loom as I turn LED spotlights which are wired across sidelight via a handlebar switch ( draw less than 1 amp each ) the voltage shown on my digital meter drops bout 0.3volts, in addition to the voltage dropped by LED headlight bulb ( 1.5 amps ) of another 0.3 volts compared to battery direct at battery....
If not direct to battery ( due to battery drain when standing ) a least I will try to get a feed as near to ignition switch as possible and hope that voltage drop there is minimal. I can see why R/R makers encourage buyers to connect it directly back to battery ( via a 30 amp fuse ) rather than through the bikes loom...
Gen1 Undertray | Strangwooduk | SV Talk, Tuning & Tweaking | 12 | 08-10-17 08:56 AM |
an Australian gen1 | giantclam | Photos | 18 | 29-08-10 10:41 PM |
K3 Battery Woes? | Rammsteinkid | SV Talk, Tuning & Tweaking | 7 | 02-12-09 04:14 PM |
Question about gen1 to gen2 transition | Zokambaa | SV Talk, Tuning & Tweaking | 18 | 20-11-08 12:19 PM |
gen 2 fender on a gen1 bike? | hitmanip | SV Talk, Tuning & Tweaking | 7 | 26-03-07 07:37 AM |
