04-05-09, 07:51 PM | #41 | |
Re: fish tailing like mad
A slide, yes. A lock, no. The difference is pretty marked. Go try it... Dave is it actually breaking loose? What tyres? How many miles? What pressures? If it just feels like it's wagging it could be anything on the chassis, swingarm bearings, a collapsing wheel bearing, a faulty tyre etc. Check carefully for any bulges on the sidewall or other obvious fault. It could even be a f##ked shock making it feel like it's moving around (or even a standard shock "working" normally!!)
04-05-09, 07:57 PM | #42 | |
When braking heavily with the front how much weight is there going to be on the back wheel? How is weight on an interface related to reaction force? How is reaction force related to static friction?
04-05-09, 07:57 PM | #43 |
So the collective wisdom of the .org is that something might have gone down on Dave - his rear tyre
04-05-09, 07:58 PM | #44 | |
Dave really go over your rear tyre with a fine tooth comb, and check to see if any 'grit and stones' could be really a tiny pinhead of a nail. The roundabout puncture I had, I missed several times, and found a tiny metal pinhead in my tyre. When rob pulled it out it was a giant bloody rivet pin.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
04-05-09, 08:01 PM | #45 |
Having a puncture itself won't affect your handling.... it's the pressures. Most "punctures" lose a couple of PSI a week..
04-05-09, 08:04 PM | #46 |
going on paddock stand for inspection during break in rain
04-05-09, 08:17 PM | #47 |
having a hole in the first place don't help either
04-05-09, 08:20 PM | #48 |
To be fair if the hole is enough to let a sizeable amount of air out, IE pressures are running low anyway, a good rider should notice by the end of his/her road. It'd weave and feel very slow to turn in.
Dave I'll ask again have you checked your pressures.....? You don't need it on the paddock stand do to that and it takes all of 30 seconds. |
04-05-09, 09:06 PM | #49 |
It can if you stall it
Silver SV650SK3, Fuel exhaust |
04-05-09, 09:07 PM | #50 |
And it can if you are trying to bump start it. Bloody impossible
Fish (not food!) | pencil shavings | Idle Banter | 17 | 19-10-08 05:11 PM |
fish and chips | AndyBrad | Idle Banter | 36 | 10-10-08 07:25 PM |
FAO Fizzy Fish!! | rigor | Soho Massive | 2 | 05-09-07 10:55 AM |
Anstruther Fish Bar | The Basket | SV Ecosse | 10 | 25-06-07 06:06 PM |
Anyone keep tropical fish? | Mark_h | Guildford Massive | 31 | 18-04-07 12:36 PM |
