Old 04-06-08, 07:37 PM   #41
zadar
Default Re: 2002 sv 650 fuel tank problem
common problem is end of pipe breaking of on top under cap.it is easy fix.
Old 04-06-08, 10:59 PM   #42
So to repair...
Tin opener, MIG welder, soldering kit and faith
Old 04-06-08, 11:46 PM   #43
zadar
no.that was opened for different reason.
Old 04-06-08, 11:48 PM   #44
I know
So how do you fix the tube with the tank still in one piece?
Old 14-06-08, 05:07 PM   #45
Stevetmanchester
ok so today i started on the leaking tube problem
found some pipe in my scottoiler box and was able to reuse it
covered the pipe in araldite and slid it through (wasnt as easy as it sounds!)
slow setting araldite so got to leave over night to set.
will update tomorrow.
cheap fix if it works £5!
fingers crosssed
Old 16-06-08, 09:54 AM   #46
Stevetmanchester
FIXED!!!
Been in the garage with a full tank of petrol and not a drop of fuel!
Cheers for the advice chris worked a treat and cheap to!
lets just hope it stay fixed!
heres a pic after a well needed clean! (with the fixed tank)
Old 10-07-08, 08:23 PM   #47
Biker Biggles
Biker Biggles's Avatar
Any update on this?Did your pipe within a pipe stay fuel tight or was it just a temporary fix?I ask because BB juniors curvy leaked a load of fuel yesterday and I fear he may have the same problem.
Old 10-07-08, 09:55 PM   #48
If they leak randomly then stop it can be carb floats..
Old 11-07-08, 08:54 AM   #49
Biker Biggles
Yes I didnt catch it "in the act"of leaking,just a strong smell of petrol.Bike was standing in a pool of water (from all that rain)so couldnt see where anything had come out.Would the carbs still overfill when the engine was off?I thought they required inlet vacuum to open the fuel tap,and power to pump the fuel.Or can an open float chamber siphon fuel anyway?
Old 11-07-08, 11:05 AM   #50
Nah can't siphon it but the vacuum fuel taps don't always close immediately, and they can flow a lot of fuel.
black SV650s 2002 tank mattglavin For Sale - SV's and SV related items 11 29-04-09 01:36 PM
Fuel tank svrich Stuff Wanted 4 30-09-08 07:45 AM
2002 sv650s K&N problem erics02 SV Talk, Tuning & Tweaking 6 18-10-07 09:52 PM
blk tank cover, service manual, fork seals for 2002 kingjoe For Sale - SV's and SV related items 0 20-04-07 05:14 AM
need fuel tank for '99 SV - will a used one be ok? FreshAL SV Talk, Tuning & Tweaking 7 08-03-06 03:51 PM
