#41 | |
Sorry if I have hijacked the thread Svgrandad
SV1000S K4, Hugger, Scottoiler. Lowers |
#42 |
Now that's a damn good question - honest answer is I don't know. same I suppose with Nikasil bores. I'll have a look into that one.
it's a big problem with diesel engines, the carbon in the oil can, if left and not changed enough, literally grind the bores smooth which polishes the honing marks away - you then get really bad oil burning and loads of smoke out the exhaust because the oil isn't sealing the rings. Spokey Last edited by Spokey; 23-02-09 at 10:40 PM. |
#43 | |
SVGrandad
#44 | |
#45 | |
Apparently Nikasil is slightly porous so acts like sintering where the oil would stick in the porous parts ... Spokey |
#46 |
If Nikasil counts as chrome plating for the purpose of the discussion, the RGV has/had it.
ogden S1000XR | 990SMT | YZF-R6 #7 |
#47 |
I plug and play.
Key in, engine running, ride away. |
#48 |
Had any trouble with non-working bikes recently?
#49 |
SV. key in, engine start, ride away. (The first time of the day. After this it requires manual pushing along road, jumping, and gabbling and stomping of levers and pedals).
Dullsville. key in, engine start, ride away. (So long as it is above 10 degrees ambient temperature.) YZF. key in, engine, start, ride away. |
#50 |
.......as long as it takes to shut the garage door. 5secs. Its all nice and easy 30 limits for me though.
Warm grips | jumjum_0214 | SV Talk, Tuning & Tweaking | 23 | 08-12-08 08:27 PM |
Oil leak when warm | AndyBrad | SV Talk, Tuning & Tweaking | 3 | 18-08-08 05:19 PM |
To warm up or not to warm up.... | DanAbnormal | Bikes - Talk & Issues | 21 | 16-08-06 04:30 PM |
tyre warm up v's engine warm up? | twotime | SV Talk, Tuning & Tweaking | 25 | 14-07-05 11:06 PM |
Warm up | BenScott | SV Talk, Tuning & Tweaking | 20 | 11-05-05 04:36 PM |
