Old 01-12-09, 07:44 PM   #41
xXBADGERXx
Default Re: cr&p :( :( :( gone down
Depends if the diamater of the hole that runs through them is the same as the one for the SV Yoke . Is the SV Yoke a threaded hole or are the risers held in place with a bolt/washer/nut ?
Old 01-12-09, 07:46 PM   #42
Should do, but I have a Sv650s with clipons
Will have risers when I do my front end conversion, which will have a new top yoke
Old 01-12-09, 07:48 PM   #43
barwel1992
its held in with a bolt (requires removal of the top yoke)
i have just found that you can get the bolt seperate that runs through the middle so might just do that
Old 01-12-09, 07:48 PM   #44
From memory the risers are held in place with a bolt?
But I may be talking complete carp
Old 01-12-09, 07:50 PM   #45
xXBADGERXx
I`d save your money mate and just run a new bolt . My mate dropped his GSX1300 in a car park with me on the back , we were sat astride it trying to keep the bugger off the deck . Eventually we ran out of strength and let the bike go and it was 1mm off the crash bars , the be all and end all of it was that his bars were not straight . He fretted about it and tried to source new risers for it . Upon taking it apart it turned out to be a bent bolt after all .
Old 01-12-09, 07:51 PM   #46
lee67
sorry to hear m8...as said happens to us all at some point, i went 26 years before my first off in may this year....least ur ok and bike is a cheap fix
Old 01-12-09, 07:56 PM   #47
barwel1992
thanks and yup verry lucky i dident need a radiator
Old 01-12-09, 08:21 PM   #48
Philbo
Bad luck mate, sounds like your OK though and the damage isn't too bad. Not a bad result really!
Hope you get your MOJO back soon!
Old 01-12-09, 09:23 PM   #49
barwel1992
thanks
right orderd my stuf well apart from one thing order brake lever £11 rear folding non snap brake leaver £27 (STEEP) and foot pegs £14 not bad total £53 ish and just going to get bolts for risers if i can should be about £4 for 2 so not bad, under £60 at least
Old 01-12-09, 09:24 PM   #50
mikelcfc
ride with no clutch and no front brake??? bin there done that
I Crashed. Sean_C Bikes - Talk & Issues 29 02-01-08 11:32 PM
Crashed but I'm ok Warthog Bikes - Talk & Issues 49 13-04-07 04:18 PM
Crashed heros Bikes - Talk & Issues 15 23-02-07 04:10 PM
crashed in to!!! goldengraemes SV Talk, Tuning & Tweaking 50 11-04-05 12:57 PM
