Old 04-02-10, 10:48 PM   #41
Default Re: Regulator chat thread.
I don't trust diode test of Reg-Rec. I've had a couple check out tip-top and be completely knackered.
The diode checks can be useful if you have a current leak that's traced back to the reg-rec, but only for that purpose, the diodes make up the rectifier, not the regulator.
Old 04-02-10, 10:52 PM   #42
5hort5
Here's a question, working on the assumption I get my hand s on one tomorrow, the yellow wires, are they just the three phases of AC then? if so does it matter which way you wire them up? Also on the off chance its has two reds and two black wires do I just solder them together into one connector?
5hort5 is offline   Reply With Quote
Old 04-02-10, 10:56 PM   #43
beabert
Yellow ones anyway round, Yes to the other question.
£35 is a good price. 50-60 is normal, mine came to just under £35 with postage, try get one thats done little milage.
Old 04-02-10, 10:58 PM   #44
Originally Posted by 5hort5 View Post
the yellow wires, are they just the three phases of AC then? Yes
if so does it matter which way you wire them up? No
Also on the off chance its has two reds and two black wires do I just solder them together into one connector? Yes
IMO it is better to put the red and black direct to battery with thick wire, ring terminals and an inline 20A fuse. But it will probably be fine feeding into stock wiring
Old 04-02-10, 11:00 PM   #45
beabert
Exactly what im doing, i might run my own wires from alternator too, ill see how i feel.
Old 04-02-10, 11:01 PM   #46
5hort5
Not sure about the mileage and zero postage so I'll have that and see how it goes, I hope you are right about these FH014's lol - I should have the little so and so connected by the end of tomorrow if all goes well and then I can turn my attention to the troublesome idle and carbs on the weekend (fingers crossed).
Fancy a carb party at mine Neeja, tools, coffee, spare carbs for parts if needed
Old 04-02-10, 11:02 PM   #47
5hort5
Exactly what im doing.
ok, yer cool, can do that, 20 amp though, I read on that twin site it need to be a 30 or is that for the bigger twins? Do maplins do the holders for em ???? - off to google
Old 04-02-10, 11:03 PM   #48
beabert
Lol @ carb party.
Old 04-02-10, 11:04 PM   #49
An assumption on my part that if the electrics can draw no more than that from the battery (main fuse), they will not draw more than that from the charging circuit.
Feel free to correct me, but also I cannot see why a 30A fuse would not be perfectly safe also to protect against fire if a wire was worn through.
Old 04-02-10, 11:07 PM   #50
beabert
I was going with 30amp too. The fh014 rectifier can put of 50amp tops ( i think), just make sure the wiring is rated above the fuse for obvious reasons lol.
The maximum drawn of the bike is way lower than 50, under 20 even. Depends what other crap you have plugged in i suppose.
Photo Comp - Chat Thread 5hort5 Photos 1254 15-06-20 04:13 PM
welsh TT weekend away (take 2) Banter / Chat thread hovis South & West Surfers 452 13-10-09 04:00 PM
North Wales Rideout #4 thread - Please use this for chat Luckypants The Border Patrol 287 26-11-08 09:44 AM
SV Ecosse Glencoe Massacre chat thread Lissa Rideouts & Meetings 66 23-07-08 01:30 PM
Booking chat thread. rictus01 2007 Annual Rideout 110 27-06-07 02:15 PM
