Old 12-07-10, 04:50 PM   #41
Rob969
Default Re: What would you like to see made for the SV?
What about saddle shutters. (Blanks that fill in the holes when you remove the Grab Handle)
Old 12-07-10, 04:59 PM   #42
barwel1992
Default Re: Do you guys need anything making....?
Originally Posted by hongman View Post
Shorty levers?
+1 although i would want some the work with the RSV brembo master cylinder
Old 12-07-10, 05:02 PM   #43
Strong, chain adjusting plates that don't twist around the swingarm would be nice
Old 12-07-10, 05:06 PM   #44
barwel1992
Darren if you bend the bottom bits up so they are tight against the swing arm they cant spin round, well mine dont
Old 12-07-10, 05:10 PM   #45
Yeh mine were tight. It was when a mechanic over-tightened the swingarm. Then the next guy to work on it couldn't budge the nut it was that tight. Then when he did get it moving it took the adjuster with it.
But they are very weak. They sometimes bend a bit when I undo it
Old 12-07-10, 05:12 PM   #46
Matts-Yokes
Ok,
We can make stuff in aluminium and delrin (a type of tough plastic/nylon)
So the list to date is:
1. Funky/sexy topyokes for SV's with clipons (identical in everyway to dizzyblondes....only joking)
2. Swingarm cover plates/bobbins
3. Rear footpeg hangers
4. Billet rear tourque arms - maybe
5. Mirror spacers
6. Some fairing spacers/brackets - Maybe tricky, but can look at it.
7. GPS/phone mounts attached to clipons
8. Footpeg lowering plates - adjustable - very easy to do.
9. swingarm adjuster plates - designed well so they dont twist
Wow...anything else!
We need an SV in the workshop for dimensions...any offers in or around lancashire, unless you want to travel
Old 12-07-10, 05:14 PM   #47
Jayneflakes
Jayneflakes's Avatar
Originally Posted by Owenski View Post
Dunno if it's possible out of the material you use but what about producing front spindles which would allow for the gsxr front end mod but keeping the current sv wheel this would be to avoid the requirement of a speedo sensor mod.
This does appeal, so hurry up and buy a lathe!
Originally Posted by liathich View Post
+1 for footpeg lowering brackets with more than one set of adjustment holes.
This also appeals, I have real difficulties some days with the standard pegs. The joy of being an old bag is that on some days, I can't get my feet down!
Jayne you're a Pussy Magnet
Old 12-07-10, 05:31 PM   #48
as long as i get them back i can send you a complete set (on card) bracket set for k3> fairings with instructions of what bits go where so you can copy.
if i dont get them back you will have a very angry kilt wearing nutter at your door
Old 12-07-10, 05:33 PM   #49
Matts-Yokes
Ha ha, i tell you what send me a photo of them first if possible so i can work out whats needed. It would be useful to have the brackets here but on a bike as it may be the best way to make them is not the suzuki way.
Send me a photo.
Old 12-07-10, 05:44 PM   #50
hongman
How diffucult are levers to do Matt?
Pazzos are way overpriced and the copies floating about arent great from what I can tell. Mostly fitting issues.
Have I made it? Luckypants Idle Banter 12 02-09-09 04:25 PM
Has anyone made home made abba stand adapters? monkey Bikes - Talk & Issues 9 31-03-09 10:00 PM
He made it. Stig Thames Valley 23 17-04-08 12:44 PM
Anyone made a will ? stewie Idle Banter 32 18-02-08 02:12 PM
Something that made me think... Baph Idle Banter 24 05-01-07 09:05 AM
