View Poll Results: How should Mr Endo best manage his bikes morning temperature
Tick over before setting off, bike hits 85 degrees before you get to work. 19 35.85%
Ride immediately from cold, if bike only gets to 60 degrees, so be it. 34 64.15%
Voters: 53. You may not vote on this poll
Old 23-11-10, 11:06 PM   #41
-Ralph-
Default Re: How should the bike get up to temp on a 2 mile commute?
Best way is to ride far enough to get it up to temperature fully.
Sid said both poll options are bad, we know he thinks idling is bad (and I know he knows his onions)
so that leaves us with
Ride from cold is also Bad?
or
Ride from cold is good, but bad if you don't get it up to temperature?
Old 23-11-10, 11:10 PM   #42
svrich
I doubt anything you do will be any better or worse for the engine, but running it for that short time/distance will damage it. As several have said, and YC above, the journey will need to be longer to get the temperature up enough for the oil to work properly. Fortunately my journey starts and finishes with about five minutes of stop start, easy throttle, 30mph riding. This allows the engine the time to get ready for my blast on the open roads. I don't wait for it to warm up before starting out though. I get the choke to a level where 1500 rpm is steady and then shut it off after a couple of junctions when it is able to hold the revs without it.
Old 23-11-10, 11:14 PM   #43
svrich
or
By the time he has waited for the bike to get up to temperature he could have jumped on a push bike and ridden the two miles to work already.
Old 23-11-10, 11:15 PM   #44
or
Use the f***ing search function seems to cover all the above options
Old 23-11-10, 11:20 PM   #45
-Ralph-
Can't be f****g ar$ed 'cos I'm going to bed seems to cover that response
Old 23-11-10, 11:23 PM   #46
Nor f**king me, I'll read the thread after someone posts the link up
Old 23-11-10, 11:31 PM   #47
If you cannot be f***ing ar$ed to search I cannot be f***ing ar$ed to write a sensible answer. Seems to cover a lot of threads appearing over last few days eh
Old 24-11-10, 12:34 AM   #48
beabert
Here you go you lazy *******s lol
http://forums.sv650.org/showthread.p...hlight=warm+up
Sounds right and justified to me, choke on just to start, turn it of as soon as possible, then open throttle a tad to warm up rather than use the choke, (Or ride at low revs until warm)
Old 24-11-10, 12:54 AM   #49
metalhead19
Originally Posted by beabert View Post
hold throttle open gently to warm up
Think my neighbors would kill me if i sat on the drive with the throttle open til the bike was warm.
But thanks for the summary, way to lazy to read them all
Old 24-11-10, 01:20 AM   #50
beabert
Not fully open, under 3k, less rich than using choke, illl edit.
What came first, your bike or the commute? thulfi Bikes - Talk & Issues 10 06-06-10 10:45 AM
sv650 rev/counter/temp gauge for race bike? ronscotty SV Talk, Tuning & Tweaking 3 02-05-10 12:34 PM
My first Commute on the bike G Bikes - Talk & Issues 20 25-05-07 10:47 AM
40 mile commute hancsj SV Talk, Tuning & Tweaking 9 15-12-06 12:53 PM
115 mile commute Warthog Bikes - Talk & Issues 22 08-06-06 07:48 PM
