Old 05-12-10, 04:12 PM   #41
hongman
Default Re: Caliper questions
Mm ok.
Reinstalled the fronts today and bled them through, lovely jubbly.
Took rear off, but this time left banjo on til caliper was off the bike so I could take out the pads and pump them out a bit. One piston is stuck, the other was doing all the movement.
Problem is, I cant get the god damn hex bolts out to split the caliper. Tried 3-in-1...think I really need a rachet hex rather than a t-hex tool which I'm using.
Maybe if I re-bolted it to the bike too....
Old 05-12-10, 04:15 PM   #42
hongman
Oh and I lost the screw that holds the metal braket onto the front brake res...anyone got a spare? ;(
Old 05-12-10, 04:15 PM   #43
barwel1992
i all ways use a ratchet hex, i find they do less damage to the bolts and you can use more torque because of the ratchet size (leverage)
Old 05-12-10, 04:24 PM   #44
The rear I split needed a ratchet hex. £5 from Halfords (3/8ths drive) and the new socket head bolts are £4 on ebay
Old 05-12-10, 04:49 PM   #45
hongman
Thanks.
Nothing like being prepared eh!
Old 05-12-10, 04:52 PM   #46
mate I had to buy one to do the rear. You got a breaker bar or large torque wrench, as I had to use a 2ft breaker bar and it still took a lot of effort.
Which piston is stuck BTW?
Old 05-12-10, 04:54 PM   #47
hongman
Its the piston on the same side as the banjo bolt.
Halford trip tomorrow I guess...
Old 05-12-10, 04:57 PM   #48
If it is same side as banjo then knock piston out through banjo hole if you already split caliper.
I have had to drill a few caliper bolts out, they can seize badly. You can mix a bit of acetone and ATF for some very effective penetrating oil and let it soak into the bolt from the back. I think acetone is the ingredient they took out of it when penetrating oils started being sh*t a few years ago.
Old 05-12-10, 05:01 PM   #49
Easiest way is as YC said. Save damaging the piston with moe grips.
I think it was Acetone that was banned for penetrating oils, as it was Benzine that was banned as a degreaser
Old 05-12-10, 05:05 PM   #50
Never use mole grips on pistons, there is always a better way.
It was trike they banned as degreaser... trichloroethylene
Caliper upgrade - Questions. lawson17 SV Talk, Tuning & Tweaking 13 14-09-11 12:51 PM
Questions, questions - light bulbs and oil leaks. garynortheast SV Talk, Tuning & Tweaking 7 25-03-10 12:55 PM
help with caliper rebuild?? arcdef Thames Valley 3 04-01-09 05:36 PM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
