#41 |
Very interested.
My original adjuster plates are already looking jaded (less than three years and 15Kmiles). Still would like to have bottom alignment hole despite any affect on overall strength. Non Oiler. Am just down road from JoshW so dont mind being part of a NorthWest group shipment .
SK9 Sport Black Delkevic can. Non arbores caesa suum mittere nuntius, sed magnum numerum electrons uehementissime incommo. Last edited by Shawthing; 18-04-12 at 07:29 PM. |
#42 |
1..joshwalker094....non-scottoiler, with hole
2..DarrenSV650S..... 3..Epic Monkey...... 4..MJC-DEV..........non-scotoiler 5..Nobbylad......... 6..muzikill......... 7..The Guru.........Non-Scottoiler 8..The Guru.........Non-Scottoiler 9.. fluffer 10.Kilted Ginger 11. Turner 12. Jayneflakes 13. SIII
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
#43 |
Manufacture em with the bottom alignment hole as standard theres no fuss that way on orders.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#44 | ||
http://www.scottoiler.com/uk/Spares-...ypage.tpl.html this then attaches to the oiler plate on the bottom of the adjuster plate. i have done a rough idea of how the finished item might look. ![]() i'm no photoshop expert ![]() now remember folks the basics are all done and it's up to you how you would like it to look. there has been questions asked about leaving the hole for the bottom marker. yes i can put a hole there but it cant be as big as the one in the original picture. we tried to do it but the bottom edge is deforming when we are bending the first bend so it will have to be reduced to allow us to bend the bracket properly. the picture above is a rough idea of how big the bottom alignment hole would be and would allow you to still see the alignment marks on the swingarm. if you would like a slot with a marker that can be done but the slot cant be a large one for the reasons above. the brackets will all be made exactly the same but those wanting an oilier bracket will have theirs spot welded to the bottom face of the left hand bracket. this makes no odds to the finished quality. Last edited by Bibio; 18-04-12 at 11:23 PM. |
#45 |
Add to list,
1..joshwalker094....non-scottoiler, with hole 2..DarrenSV650S..... 3..Epic Monkey...... 4..MJC-DEV..........non-scotoiler 5..Nobbylad......... 6..muzikill......... 7..The Guru.........Non-Scottoiler 8..The Guru.........Non-Scottoiler 9.. fluffer 10.Kilted Ginger 11. Turner 12. Jayneflakes 13. SIII 14. peterco
SV650 Sport in Black MZ saxon tour 301 Previous bikes SV650 Naked BMW 650cs Scarfer MZ RT 125 4 stroke |
#46 |
Add to list,
1..joshwalker094....non-scottoiler, with hole 2..DarrenSV650S..... 3..Epic Monkey...... 4..MJC-DEV..........non-scotoiler 5..Nobbylad......... 6..muzikill......... 7..The Guru.........Non-Scottoiler 8..The Guru.........Non-Scottoiler 9..fluffer 10.Kilted Ginger 11.Turner 12.Jayneflakes 13.SIII 14.peterco 15.tetol ??? 16.twinset........Non-Scottoiler 17.Davy.h ??? 18.Speedy.........Non-Scottoiler 19.Shawthing?? once we start hitting the 30's then i will PM those on the list Lance |
#47 |
2..DarrenSV650S.....scotoiler, not bothered if it has a hole or not 3..Epic Monkey...... 4..MJC-DEV..........non-scotoiler 5..Nobbylad......... 6..muzikill......... 7..The Guru.........Non-Scottoiler 8..The Guru.........Non-Scottoiler 9..fluffer 10.Kilted Ginger 11.Turner 12.Jayneflakes 13.SIII 14.peterco 15.tetol ??? 16.twinset........Non-Scottoiler 17.Davy.h ??? 18.Speedy.........Non-Scottoiler 19.Shawthing?? |
#48 | |
I can't quite figure out what's going on with the scottoiler plate in your original picture but stick me down for a pair anyway. Shiny new plates might finally encourage me to fit my old scottoiler! Oh, and good work Lance! Edit - oh crap, i screwed up the add name to list thing! Last edited by sputnik; 18-04-12 at 11:41 PM. |
#49 |
Go on then add me to the list
21. Elliott Woodruff - Non-Scottoiler Any chance of polished stainless? |
#50 |
I'm in Bibio
potential pointy ecu restrictor kit bargain | haydensv650 | Stuff Wanted | 0 | 18-08-11 07:40 PM |
Replacement chain adjuster plates? | SV400Rob | SV Talk, Tuning & Tweaking | 13 | 02-02-11 09:30 PM |
chocolate chain adjuster plates | dmracing | SV Talk, Tuning & Tweaking | 6 | 01-08-09 09:23 PM |
Chain adjuster plates | dmracing | Stuff Wanted | 6 | 24-07-07 05:54 PM |
Stainless adjuster plates.....................bling | svrash | SV Talk, Tuning & Tweaking | 19 | 23-04-06 07:22 PM |
