Old 19-06-13, 10:17 AM   #41
dirtyred619
Default Re: Continuing battery problems.
Yeah wasn't sure which setting to put it at but here's the readings:
2000u - 1
20m - 1.
200m - 85.5
Am I right in thinking that 0 means no draw and a reading means there is a draw or is it the other way around?
Old 19-06-13, 10:39 AM   #42
aesmith
I can't quite make sense of the scales you quote. It sounds as if it's drawing 85.5 "somethings" which gets rounded up to 1 "something" at the higher ranges.
If it's 85.5mA (Milli Amps) than that's too much, and will flatten your battery in less than a week. 85.5ľA (Micro Amps) then that's virtually nothing.
Old 19-06-13, 10:43 AM   #43
Pete7
Pete7's Avatar
As a guide,
12.7v fully charged and rested for a few hours.
12.2v = 50% charged
12.0v = 25% (or flat as AESmith said).
Do bear in mind that the whilst the digital meter will display to 0.1 most aren't that accurate unless you have a large Avo type. I have two on the boat and there is a difference in readings between them.
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 19-06-13, 11:33 AM   #44
dirtyred619
I'll try and take a pic of the display it will hopefully be clearer. It is strange though as it was 6 days between being used and then not starting this most recent time.
Old 19-06-13, 11:36 AM   #45
dirtyred619
Originally Posted by Pete7 View Post
As a guide,
12.2v = 50% charged
Pete
Thanks for the info. Off current readings its certainly looking like the battery is fine and I'm again more inclined to say its current draw from somewhere. At least I've got time to try and diagnose this before I next plan on being on the bike.
Old 19-06-13, 06:49 PM   #46
dirtyred619
Well at about 5 the battery was still at 12.66 so that's encouraging. Here's the pick of the reading of the current, hope I did it right. Was a struggle to take the reading, support the multimeter and take the picture at the same time! Reading was the same as before but my hand slightly slipped as the camera took the picture.
Old 19-06-13, 09:05 PM   #47
aesmith
That looks like 84.8mA I'm afraid.
Old 19-06-13, 09:31 PM   #48
dirtyred619
So I should start looking for loose wires/connections etc then? Weird thing is the voltage on the battery hasn't dropped at all yet today!
Old 20-06-13, 08:30 AM   #49
dirtyred619
Battery been hooked back up now for a day. Reading this morning - 12.64v, so not dropped off at all. Surely if there was a higher than expected drain there would be a drop in charge by now? I'm begining to think I should just take my chances and keep the battery on an optimiser at least once a week. Battery seems to be holding it's charge both off and on the bike (at least upto now) and everything else seems fine. Only thing I can think to do now is take readings before I next go out on it and get a decent ride in with a couple of stops etc. All being well, any readings taken once back should re-confirm, at least in my eyes, that the charging system is working, or am I wrong there? I.e. if it's 12.64v before the ride, it should be the 12.64v once back.
Old 20-06-13, 09:11 AM   #50
stuR
Personally as someone that doesnt know much about electrics, if i had your problem and charging the battery once a week or so ensured it didnt happen, i would just do that. Yes its not ideal but if you can make it work like that its gona save you alot of hassle in tracing a problem
Battery problems sonicated SV Talk, Tuning & Tweaking 6 01-03-11 03:33 PM
Anyone had problems with Battery? Springbokki SV Talk, Tuning & Tweaking 2 30-06-09 09:55 AM
Battery Problems SV Meldrew SV Talk, Tuning & Tweaking 9 04-02-09 10:54 AM
Battery problems gerbrox Bikes - Talk & Issues 4 21-08-08 12:31 PM
Battery Problems Dom_ SV Talk, Tuning & Tweaking 7 19-06-05 10:10 AM
