#41 | |
I will also change the channel tonight and re-boot the hub. Regards |
#42 |
So does anyone know of a good router to use so that I can ditch the hub's wireless?
#43 | |
Do the ports first and get that sorted, then once that is done run the speed so it tracks the optimum. I used to have to actually go in and manually forward ports on my old virgin router and belkin but the super hub seems to work ok once utorrent is set
2011 Triumph Daytona 675, Arrow exhaust and QS! |
#44 |
there is a new VM superdud being user tested at the moment. It still isn't perfect.
Background, VM introduced the knobbled netgear hub as a response to users who wanted to do more than plug a single PC into a modem and expected VM to provide them with tech support for hardware/installs they knew nothing of. My own advise. use the hub in modem mode. Install a decent throughput nat router/firewall. (mine will happily cope with > 600Mb) and put your own network behind that. You do not need to use the superdud as a router. But you need either a VMG 300 or superdud 2 to get VMs cable service at a reasonable speed. Then shove an 802.11ac router to give the a reliable wifi element of the superdud
Not Grumpy, opinionated. |
#45 |
Recommends on a good home router? ie easy to set up/maintain, quick and reliable?
#46 |
Just ordered a Cisco Linksys E3000 as a few cable/digital forums highly recommend them. The other option was an ASUS RT-N66U but they'ms a bit expensive for my pocket!
Single Seat Cowl """damaged""" | lechatenetpat | For Sale - SV's and SV related items | 8 | 05-12-12 03:03 PM |
"33bhp?" Yes "i dont believe you, I'll seize your bike and take you to court" | Flameboy | SV Talk, Tuning & Tweaking | 936 | 20-10-10 07:06 AM |
Apparently "gingers" are really funny people! | gruntygiggles | Idle Banter | 51 | 22-08-10 09:42 AM |
technical support - dlink wireless router & virgin media broadband | Paul the 6th | Idle Banter | 9 | 18-06-10 04:03 PM |
teh "what you doing this weekend thread"...sponsored by Chesley "Sully" Sullenberger the Third | keithd | Idle Banter | 30 | 18-01-09 11:47 AM |
