#41 |
Just to clarify. It was different garage that had it for the aux belts.
#42 |
Surely if the original garage failed in their service and only changed one of the two belts then they should be paying as if they had done their job properly then all this would of been avoided?
Sent from my GT-I9300 using Tapatalk |
#43 |
In an ideal world. Probably won't happen.
I have had it confirmed though that the belt that failed was the outer belt. They will have had to remove it to replace the one they did and then put it back. Doesn't sound like a coincidence to me. |
#44 |
Get a second quote for the repair work, that sounds a lot for a few new valves, which are quite cheap to buy.
What about looking for a 2nd hand replacement head? Be cheaper to swap a head than rebuild one. |
#45 | |
#46 |
MBK, sorry to hear about this, hope you get a cost effective solution. Good luck!
Bikes I've owned and loved: Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R |
#47 | |
It's due to it being the ST model Phil. The quote is reasonable. |
#48 |
Sorry old girl but it obviously confirms what my mate said about a "Contributory factor"
Go back to motorbikes ,you had better luck with them |
#49 | |
My mate had his v6 Audi rebuilt with all new valves and belts etc for less than that. Trouble is they have you over a barrel and being a female customer, they have probably piled it on, in fairness unless you're clued up, there's no way of you or anyone else checking to see what they are telling you is correct. |
#50 |
Phil, don't imply that I'm an idiot because I'm female.
The recovery was almost £200, it's taken 4 hours to strip cylinder head so another £120 before we even start, the cost of the parts (shims and valves) are £400, then the labour for the rebuild of the head, then new belts and I can't remember if he said I needed a new pump or not. So no, I don't think I'm being scammed or that they are being unreasonable. A 2nd hand head is not cheaper than the rebuild. It was an option that was looked at. The T5 engine is known to be labour intensive in these sort of situations. |
New Ford Focus | widepants | Idle Banter | 29 | 16-04-13 03:55 PM |
Ford Focus or something else? | Amplimator | Idle Banter | 28 | 01-02-11 10:39 AM |
Little warning for Vectra C Owners | -Ralph- | Idle Banter | 16 | 21-10-09 10:06 AM |
Soft Focus | Alpinestarhero | Idle Banter | 28 | 08-10-09 12:22 PM |
