Old 12-01-18, 01:20 PM   #41
Dave-the-rave
Dave-the-rave's Avatar
Default Re: 2005 SV650s Valve Clearance Question
Yes Fowler is ok.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Old 12-01-18, 08:20 PM   #42
egcSV650s
I done what you said about turning the crank to F and its all lined up properly at the rear now so all good, thanks.
Only thing now is where the pictures in the haynes manual show where the marks lining up to the chain are meant to be mine are different but will this matter? Its like it on front and rear cylinder before i touched anything. Ive attached pictures showing what i mean. Where it says number 1 on where the chain should start my number 1 is where ive circled the chain ring on the picture. The markings on the sprockets are where the haynes are but my chain is over to the right 1 link more than the haynes one, will this matter.
egcSV650s is offline   Reply With Quote
Old 12-01-18, 11:40 PM   #43
Dave-the-rave
No that's fine. Mine was like that as well. Important when re installing them is the 16 pins as indicated in the diagram. Also ensuring there's no slack in the front of the chain between the crank sprocket and the cam sprocket. All the slack must be on the back of the chain on the tensioner side. It'll be clearer when you put them in. Take some clear photos as well before disassembling for reference later.
SV650N K1
Old 13-01-18, 08:57 AM   #44
egcSV650s
Great thats perfect then. Yeah ive been taking photos always good to do that makes it easier if i forget where things go or just for reference. Thanks alot for all your help and everyone whos given me info. Ive ordered the parts so should come Tuesday and will let you know how it all goes once its back together.
Old 26-01-18, 05:53 PM   #45
egcSV650s
Just an update. Only got round to finishing the bike today and put it all back together and went to fire the bike up struggled a bit as its besn sitting for 5months but started perfect. Sounds lovely and smooth. Thank you everyone for all your help. Really appreciate it
Old 26-01-18, 10:55 PM   #46
Dave-the-rave
Outstanding. Now read up on how to sync the carbs.
SV650N K1
valve clearance/service/leakdown question sputnik SV Talk, Tuning & Tweaking 13 29-03-14 02:51 PM
Quick valve clearance question arcdef SV Talk, Tuning & Tweaking 4 29-06-10 03:48 PM
quick valve clearance question rob13 SV Talk, Tuning & Tweaking 2 12-02-08 12:14 PM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
