Old 08-10-06, 10:22 PM   #41
hovis
there is not a stong smell of petrol,
not like if a 2 stroke floods
Old 08-10-06, 10:27 PM   #42
fizzwheel
fizzwheel's Avatar
I'm really not sure but if you have eliminated the electrical side of things, then time to start looking elsewhere.
Old 08-10-06, 10:30 PM   #43
hovis
i use the choke in the morning, let it run for 1 min(at high revs choke) then knock the choke off & it go's down to 1500 revs
Old 09-10-06, 12:02 PM   #44
hovis
mogs is lending my a plug spanner
so watch this space
Old 10-10-06, 09:24 PM   #45
oldie
I've seen people use the choke when they try to re-start a warm engine and it soaks the sparkplugs, but starts ok when it's cooled down!!!
Oldie
Old 11-10-06, 07:24 AM   #46
hovis
i have got 2 new plugs, i have got the rear 1 out, the front 1 is coming out this morning(dont know now but it is)
but its a bit tricky to hold in clutch, hold plug & press starter
Old 11-10-06, 08:15 AM   #47
hovis
took both plugs out both sparking good. so i tested new plugs b4 fitting, one was good the other did not spark, so i checked all plugs in both end caps....no spark at all ,but as i said it was sparking nice, then just stopped
front plug is tricky to get out but i did it with my sockrt set
Old 11-10-06, 08:21 AM   #48
John Burt
It sounds as if you have a problem with your ignition circuit, check the low voltage side of the coils, under the tank LHS from memory - don't forget a good earth is important for the coils.
Old 11-10-06, 08:42 AM   #49
hovis
so no spark last night, then spark this morning
not sparking now .....hopfuly it will spark somtime today
i cant belive the fuss you all made about getting the front plug out
Old 11-10-06, 10:47 AM   #50
hovis
still turning over but not sparking .but i have now noticed a clicking noise coming from the battry area
Starting probs gdharbourne SV Talk, Tuning & Tweaking 13 10-12-07 08:51 PM
reg rec probs maybe dizzyblonde SV Talk, Tuning & Tweaking 4 27-09-07 04:07 PM
starting probs.....race can? hovis SV Talk, Tuning & Tweaking 8 08-10-06 09:54 PM
more probs hovis Idle Banter 6 02-10-06 09:05 AM
Starting probs The Mass SV Talk, Tuning & Tweaking 2 09-11-05 01:44 PM
