Old 01-04-07, 04:32 PM   #41
zunkus
Default Re: R1 front end?
Does your speedo still work? If you couldn't fit the pick-up wheel in front you could fit it in rear and the speed will still be reliable. I've seen this done in a US forum. If I remember correctly you substitute the rear spacer for the pic-up and extend it's cable.
Old 01-04-07, 04:40 PM   #42
r4ce_e3nd
At the moment it doesn't work, that's true. I was planning to put in on the rear axle/spindel, but first I want to finish the front end. But thanks for noticing! Putting it on the front wheel is no option because there is just no room for it.
But it is creepy to ride with no speedo, especially (yes my English is very good ) when I come near a speedingcamera it is always guessing if I'm not riding too fast.
Old 01-04-07, 07:37 PM   #43
BILLY
For the speedo you want one of these!
From this guy in the US climb.high@version.net just let him know what parts you used!
As for the TL1000s clipons the will give you the rise you need!
Old 01-04-07, 10:02 PM   #44
r4ce_e3nd
I will contact him about that speedo! Thanks for the email-address. I did read about this solution too, still have to think about which to use though.
Is there a lot of work involved to let the steeringlock work? I guess it's only a little filing?
Old 01-04-07, 10:06 PM   #45
BILLY
To be honest I forgot to ream the hole out on mine before I put the plastics back on so ATM I have no steering lock You just need to widen the hole on the frame a little!
Old 01-04-07, 10:13 PM   #46
r4ce_e3nd
Lazyness, are there any solutions to it?
I could have tought about that too to be honest, but I was to lazy... I will do it when I have my clipons, found a couple today in Holland. I hope they will be as long as the SV ones because with the R1 clipons I had trouble with all the instrument ons the handlebars.
Old 01-04-07, 10:15 PM   #47
BILLY
The TL1000s are a perfect fit for the switch gear!
Old 01-04-07, 10:20 PM   #48
r4ce_e3nd
The TL1000s' are on my way!
Old 01-04-07, 10:28 PM   #49
TL1000 clipons = very nice option, they're a bit slopey though. I figure on replacing mine with some LSL Match High-offsets, similiar rise but a bit flatter. Also much nicer to look at
The rear wheel speedo thing, well, I wouldn't do it again now. The kit in the pics there is very good but bulky, I like my new solution- the sensor off a Veypor. Costs about the same but it's much, much smaller and neater. Unfortunately you need to buy the whole thing and throw most of it away, you can't just get the sensor- I'll make a home for the rest of the loom
Looks damn fine that... How are you finding it for steering stops?
Old 01-04-07, 10:38 PM   #50
r4ce_e3nd
Errr, what do you mean with "finding it for steering stops" ...
But I don't know about the rear wheel speedo mod, it doesn't look "strong" enough for me.
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
