Old 27-04-18, 05:55 AM   #5051
Kenzie
Kenzie's Avatar
Here you can see the hook isn't properly engaged and it will mis-fire.
Here its latched properly:
You can just make out the broken spring remain (arrowed red)
Old 27-04-18, 11:57 AM   #5052
johnnyrod
johnnyrod's Avatar
Are you sure it's broken, not just displaced? The screw on the main lever has certainly seen some action, unless it was you then you're not the first person to get in here. Best option would be to replace it if it is broken, not sure where to get one though.
Old 27-04-18, 11:59 AM   #5053
Kenzie
Kenzie's Avatar
Definitely broken, I found the remains under the bulb lever. I don't think I'm the first in there, the speed ring retaining ring wasn't very tight. I have loads of springs to try but don't want to undo the main and loose tension.
Sent from my Xperia using Tapatalk
Old 27-04-18, 01:24 PM   #5054
johnnyrod
johnnyrod's Avatar
Look at it this way, someone put it together! I doubt it's impossible. Never done it though.
Old 27-04-18, 03:54 PM   #5055
yokohama
LoL. I look at it that way too - and then when I totally mess things up, realise that the someone is much cleverer than me.
Old 27-04-18, 07:12 PM   #5056
Kenzie
Kenzie's Avatar
That moment when the xv switch spring/plate ptings off somewhere as well as the blade return spring. I had to split the shutter again to check out the spring. I've fixed the original problem and found a replacement return spring but now stuck without the xv spring...
Old 27-04-18, 08:34 PM   #5057
Kenzie
Kenzie's Avatar
I think I'll have to abandon this one for now. The spring I used is too strong and activates the shutter as its ****.ed.
Old 28-04-18, 05:24 PM   #5058
yokohama
Lordy!!!
https://www.gumtree.com/p/non-digita...ses/1296707577
Old 28-04-18, 05:26 PM   #5059
Kenzie
Kenzie's Avatar
That'll be fine by now, great price too! Busy day today, just put an offer on a house!!!
Old 28-04-18, 06:05 PM   #5060
yokohama
Aye, probably long gone at £35.
Buying a house?? I suppose you need an extra room to store all the cameras.
