Old 21-08-18, 09:17 PM   #5471
Kenzie
Kenzie's Avatar
Thanks for the heads up. I just need to hook the release bits back in and it should be ok. Hope you don't mind me grabbing it?
Old 21-08-18, 09:35 PM   #5472
johnnyrod
johnnyrod's Avatar
Nah, I already have more than I use after all, it was the chance of a bargain! I also found a Beier Vauxhaul on ebay last night, it's quite similar to the Certo Super Sport Dolly so am keeping an eye on it, 173477402270
Old 22-08-18, 06:12 AM   #5473
Kenzie
Kenzie's Avatar
I've had a tinker with the Vitessa and found a couple of issues. The shutter ****.ing now works but the shutter releasr is damaged and keeps getting stuck, I can work around this but it's not pretty and will need further investigation. Also, I don't know if the film advance is working, not sure how to test.
Sent from my Xperia using Tapatalk
Old 22-08-18, 01:45 PM   #5474
johnnyrod
johnnyrod's Avatar
Pics! What do you mean about the film advance? Or is it one with a separate advance and the film turns the sprockets?
Old 22-08-18, 06:10 PM   #5475
Kenzie
Kenzie's Avatar
Problem with the release not coming back up.
Old 22-08-18, 06:13 PM   #5476
Kenzie
Kenzie's Avatar
Box of things should have the answer.
Old 22-08-18, 07:14 PM   #5477
Kenzie
Kenzie's Avatar
I think I've fixed it. Used the small spring in the above photo at the top and tweaked the shaft and it seems to work. Rangefinder adjustment needs checking but looking good.
Old 22-08-18, 08:28 PM   #5478
johnnyrod
johnnyrod's Avatar
Good work. That spring was fubar, did you find it like that? Has someone been in there already?
Old 22-08-18, 08:35 PM   #5479
Kenzie
Kenzie's Avatar
No, I did that. But the end was stretched over the stop which meant it didn't work properly. It wouldn't come off so had to pull it out. Just got to figure out how to stop the charging plunger becoming detached from the other side. Easiest way is to open the door and tip the camera upside-down and it slides back in to place.
Old 23-08-18, 07:49 PM   #5480
Kenzie
Kenzie's Avatar
There was a little history attached to the Vitessa. The seller's father bought it new in 1952 and it was passed to him when he went travelling. So what are you lot up to?
