Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
23-02-10, 05:35 PM | #551 |
Re: COD Modern Warfare 2 - PS3 player list
I want to play but I am still at work and then I have to go out after
2015 GS 1200 Adventure |
23-02-10, 05:36 PM | #552 |
23-02-10, 06:18 PM | #553 |
Not Fizzwheel
Lenny / Zig, recommendation if you wanna increase your killstreak.....or at least it worked for me.....
Use m4a assault rifle with FMJ, with Scavenger pro - as you get shed loads of bullets and can last ages. Then use stopping power, then have on anything you fancy as third perk, I usually use steady aim. Until I started doing that I also struggled or came even. But this combo seems quite good.
My Bike Now Doesn't Have a Motor....Just Pedals!!!! Hovis RIP Buddy - 13/08/1975 - 03/10/2009 "Feckinnnn Unluckkeeeeeeee"
23-02-10, 06:25 PM | #554 |
Do you camp in the same place or run around a lot. I have started to get a bit better by staying in the same area but moving about in that area. Only problem is I get bored if I dont see anoyone for a couple of minutes so go hunting for them and then get shot.
23-02-10, 06:32 PM | #555 |
Not Fizzwheel
Stay in a focal poitn, but move around. I often use heartbeat monitor, as you can quickly swivel and check if people are coming the other way. As an example, on Afghan, in the main bunker area, move between the two entrances of the main bunker, when you are by the one that leads to the poppy area, spin, of you see red dots just move round the corner so you can see the door etc. Then shoot as they enter, as soon as you kill them check the heartbeat monitor, if clear, go back the other way.
Keep doing that movement.......the main thing, is if loads pop up on radar or heartbeat monitor, throw a grenade, then crouch behind something. Only shoot openly when two or less are in front of you.....anymore and one will likely kill you. It works for me, but some prefer just legging it. I try and do a bit of both.
23-02-10, 06:47 PM | #556 | |
23-02-10, 06:50 PM | #557 |
the trick is to stay within a defendable area that you know well, ie, bottle neck, entrance, quick exits, cover etc. if you get a kill, fall back but keep sight on that position as 90% of time the same guy will come back for revenge kill, don't camp as others will work you out and flush you out with nades very quick. so keep moving around within this area, draw them in and ambush them. if you can, have two of these defendable area and move between them
24-02-10, 11:20 AM | #558 |
i never use a heartbeat monitor its for noobs
dont use the thumper or noob tube any more there for noobs with no skill i use the intervention without silencer quick scoping and the spas as back up and im having more fun doing this and not careing about the kd. i find the top 4 assualt rifles are 1. famas 2. tar 21 .3 acr 4. scar-h but each to there own . can anyone do the throwing knives, i bloody cant |
24-02-10, 11:29 AM | #559 | |
24-02-10, 11:40 AM | #560 |
Not Fizzwheel
Agreed, they can be for noobs, but nowt wrong with using the heartbeat monitor.
People want different things from the game. If you want to increase your kill streaks.....then these so called "noob" tools help. I go through times when I want to use sniper rifle and have the intervention now maxed out including fall camo......but some people just don't like sniper rifleing.
COD: Modern Warfare 2 | rob13 | Idle Banter | 424 | 17-01-10 06:36 PM |
COD Modern warfare 2 Prestige edition Night vision... | ThEGr33k | Idle Banter | 41 | 09-10-09 05:10 PM |
COD modern warfare 2 | rusty76 | Idle Banter | 47 | 06-10-09 05:47 PM |
modern warfare 2 multiplay | jans1971 | Idle Banter | 11 | 28-07-09 05:38 PM |
modern warfare 2 thread | zsv650 | Idle Banter | 38 | 24-07-09 08:31 PM |
