09-11-15, 04:06 PM | #571 |
Re: What have you tinkered with today?
Checked bike, pre mot, bloomin LED number plate light isn't working
Its OK it came with a spare, which I found straight away Strip away heat shrink I cut old one off Go to electrical kit, where's my god dam soldering iron Its ok, I've got another one Finds box Who took the plug off it
09-11-15, 04:40 PM | #572 |
Lol mav
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
10-11-15, 12:05 AM | #573 |
Bleedy car boot catch. Two hours in the rain dismantling, cleaning, lubricating, and re-assembling the sodding thing.
10-11-15, 06:05 AM | #574 | |
Found my other soldering iron after going to Homebase and seeing they wanted £20 for a new one! Feck off, screwfix only wanted £8! Soldered the new led on, low and behold it still didn't work New pair ordered off ebay for £3, all wired and ready to go, one for now, one spare. Gonna get me one of them gas powered soldering irons, as both my electric ones don't cut the mustard.
12-11-15, 09:55 AM | #575 |
A CBF 125 Just got hold of a nice one at a bargain price for my son, using it myself while I wait for a rear bearing to turn up for the SV - rear suspension has finally given up after 4 years of advises for increasing play
As long as you keep firmly in mind that it's a little 125, it's surprisingly decent, especially once you hit the smoke, where you can't use a bike's top speed in any case!
Riding a V-strom, well it has an Sv engine, don't it Last edited by Swin; 12-11-15 at 09:58 AM. Reason: added to post :) |
13-11-15, 06:28 PM | #576 | |
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am. 05 SV650s now with proper suspension, hurrah! |
13-11-15, 07:12 PM | #577 |
Laptop backed up for win10 and the start of all taped media being turned into digital files. Getting rid of the casettes and dvds soon.
Sent from my GT-I9505 using Tapatalk
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
13-11-15, 07:45 PM | #578 |
Yep, just bought one, fed up with carp electric ones
14-11-15, 02:16 PM | #579 |
What one did you go for, I got the 70W one for about £15 on some offer but I've found it's not quite got the juice to shift old blobs of solder off contacts so I've been eyeing the 120W for myself at Christmas?
Also changed the oil on the SV, realigned the rear rack as it was starting to twist where one of the mounts was working loose, cleaned and checked all the connectors for the heated grips (still switching themselves off unexpectedly but quite a bit warmer now there's a few more V's getting to them), and glued my throttle grip back on, again (must learn to be more gentle with it!) Cleaned the downpipes and all the bits of the engine that I could get to whilst I had the lowers off as well.
Blue K9 Pointy - Squished by a car/kerb/wall Blue K9 Pointy #2 - Nearly at 120,000 miles! |
14-11-15, 04:56 PM | #580 |
Charging system test, 14.7 @ 5000 and 14.5 @ 2500. All good I believe
