#5811 |
#5812 |
"The Bright Side of Life" (North Korean version)
https://www.youtube.com/watch?v=ifLqzLEB3E0&t
2016 SV650AL7 2023 GSX-8S |
#5813 |
#5814 |
Harley built its loyal following on cruisers, the XR never fit into that lifestyle despite Harley's successful flat track career. Harley loyalists shunned it because of that, none-loyalists shunned it because it's a Harley and, other than its looks, other bikes could do the same thing better.
#5815 | |
shiny shiny is not always best. you also have the added hassle of installing all your configured software again at which point you find out that you have to buy it all again. |
#5816 | |
John T
I'm not one for spending money for the sake of it and I'm becoming a bit of a tight **** in my old age. Sent from my SM-T510 using Tapatalk
#5817 | |
i would hazard a guess that there is stuff in the startup that needs turned off. pretty much everything apart from antivirus and driver interfaces can be turned off. you can also turn off "call back" driver updater's etc.etc. your system more than likely needs a good old gut out of redundant files. if your machine was sprightly before and your doing the exact same things then its just need a good old spring clean. what OS are you using? i'm also a tight git and still on an amd fx 4200 and see no need to change. |
#5818 | |
John T
#5819 |
a nice shiny should see you faster then
![]() tip: spend most of the money on the graphics card. always get the higher processor speed than cores. if you can get say a 6 core instead of an 8 core but the 6 core is 4Ghz than an 8 core 3Ghz. if you can splash the cash get an M.2 ssd for your OS but dont get an SATA type. the OS HDD is always the bottleneck so the faster you can make this the faster the overall speed of things loading. |
#5820 |
my smile is finally getting OTG to work with my POS Oppo A74 5g plugged into my new DAC.
what made me smile | kiggles | Idle Banter | 1 | 07-04-11 09:00 PM |
Smile :o) | Speedy Claire | Idle Banter | 5 | 07-10-10 08:21 AM |
To make you smile | gruntygiggles | Idle Banter | 7 | 03-06-10 12:45 PM |
Smile... | the_lone_wolf | 2009 Annual Rideout | 14 | 31-07-09 01:01 AM |
First smile | kitkat | Photos | 12 | 08-02-09 08:55 PM |
