#51 |
Hi all
Many thanks for the hints & tips to a newbie rider who needed to get a new chain & sprockets fitted. I ended up ordering a Kit from Stealth products http://www.stealthproducts.co.uk/ who were recommended on here. Ended up with Renthal Sprockets, and new X-Ring chain for £86. Got it fitted for £50 at my local Suzuki dealer (who took about 15 mins to do it start to finish!). Thanks again for all the input, am well chuffed that I managed to save £50 off the original dealer price for a standard O ring replacement. Ta Iain |
#52 | |
I have 3 different riveters. The official DID one, the official RK one. These cost around £85 each. I also have a 'Whale' riveter which is the one I use mostly these days, as I tend to supply Tsubaki chain which have solid tipped pins. The 'Whale' costs around £55, is very robust, & can be used on CLF type rivet links, (these are the ones with a dimple in the tip of the pin). However, using the 'Whale' on a chain when it's fitted to the bike is a little tricky, & requires practise to get it right. It can also be a bit painful as you have to hold the riveter whilst striking it with a hammer, & you can scrape your knuckles on the rear wheel if you're not careful. (ask biker Billy). It's not a problem for me cos I'M HARD!! ![]() Cheers. |
#53 |
Pfft Southerners.
Do you ever use the technique of putting a big hammer behind and hitting with a small hammer from the outside of the chain?
#54 | |
![]() I used to use the time honoured two hammer technique to good effect, back when God was a boy, & I had hair! ![]() When using the Whale riveter there's not enough room on most bikes to get anything behind to support the Whale when clouting it, & there's always the danger of something slipping a damaging the wheel or swinging arm. So I prefer to let my MANSIZE southern hands to do their stuff. When using the Whale it really helps to have the chain tight, & the bike in gear. I find around 3 or 4 sharp taps with a 2lb club hammer to be enough. Cheers. |
#55 |
Thanks for all the useful tips..... I've printed off the linky info, ticked all the boxes for the tools, picked up an Xring and standard sprocket (£124 in total)
I've bought a riveter/ chain splitter thingy (£24 thanks to Mr Honda). Ready to rock and roll |
chain + sprocket | SVTristan | SV Talk, Tuning & Tweaking | 2 | 08-05-09 03:01 PM |
Chain and sprocket | CodeJACK | Hardware | 5 | 18-04-08 01:24 PM |
Sprocket/Chain | Mr. Bob | SV Talk, Tuning & Tweaking | 2 | 03-05-07 08:43 PM |
chain and sprocket replacement | sv650gerbrit | SV Talk, Tuning & Tweaking | 5 | 11-05-06 09:48 AM |
Chain and Sprocket | Ernie B | SV Talk, Tuning & Tweaking | 6 | 04-05-06 12:35 PM |
