Old 25-08-20, 07:45 PM   #51
gadget
Default Re: Gen1 battery woes again!
I'm going down the 'voltage gauge' route too, have you seen the 12v volt gauges that have an 'on-off' switch on ebay? About £6.00 . So you can have the gauge wired direct to the battery and choose either on or off while you ride.
gadget is offline   Reply With Quote
Old 25-08-20, 08:15 PM   #52
SV650rules
Would want it on all the time when engine running as it is there to let you know if a problem happens in time to take some action, I would turn it off while parked to stop it drawing power ( although only milliamps ) will compromise and connect it direct to ignition switch controlled supply or maybe use a relay controlled by an switch controlled supply at least to take all those voltage dropping connections out of circuit.
Just had a thought - I have a direct to battery charging lead with SAE plug on it, may use another spare SAE lead to connect voltmeter into same plug - as I will never want voltmeter and charger plugged in at the same time, the charging lead is fused as well right next to battery + so it would be a win-win....
update - after connecting the voltmeter direct to battery by re-purposing an old SAE plug and cable it reads maximum 0.1volts low now, so all the inaccuracy I was seeing was the volts drops in bikes cable loom and plugs -( every day is a school day ) - loom was dropping up to 0.3 volts with LED headlight and sidelight ( The LED headlight draws 1.5 amps, a normal 55/60watt filament draws about 5 amps and LED sidelight draws a few milli-amps compared to 0.5 amp for a filament one ). When I turned on LED spots drawing about 0.7 amps each the volt drop hit 0.6volts. Downside is I have to plug voltmeter in if I want to use it ( I unplug when parked for battery drain ).
2016 SV650 AL7
Gen1 Undertray Strangwooduk SV Talk, Tuning & Tweaking 12 08-10-17 08:56 AM
an Australian gen1 giantclam Photos 18 29-08-10 10:41 PM
K3 Battery Woes? Rammsteinkid SV Talk, Tuning & Tweaking 7 02-12-09 04:14 PM
Question about gen1 to gen2 transition Zokambaa SV Talk, Tuning & Tweaking 18 20-11-08 12:19 PM
gen 2 fender on a gen1 bike? hitmanip SV Talk, Tuning & Tweaking 7 26-03-07 07:37 AM
