#51 |
Just Ballast
Nice job Dizzy
![]() You've got the bug now though...............you'll be buying a polishing wheel next ![]() To answer your question about the bellypan, you have to remove it for an oil change, and it's easier to pop it off for doing the downpipes too. It's ever so easy, just 4 bolts, and because it fits perfectly it's a doddle.
If It's Too Loud, You're Too Old! I'd Rather Have Two Big Bangs Than Four Little Strokes |
#52 |
There used to be some stuff called 'Vim' on sale in the UK. It sounds very much like that. Sort of abrasive and detergent?
#53 | ||
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
#54 |
If I take the full system off to polish it can I just re-attach it with what I've got or do I need to replace the gaskets?
#55 | |
Just Ballast
![]() ![]() ![]() You've obviously never taken a full system off before, have you? It's a B*TCH! It can be done, but Pete swore...................a lot! You may possibly need one new seal, unless you split the system.
#56 |
I believe you'd have to replace the gaskets.. but I'm not the mechanic...cue chris!!
oh and it'll take you about three weeks of soaking and a stud extractor to get the exhausts studs out, thats right after you anglegrind the nuts off the studs, its not a quick job
#57 |
Nope, never!
Maybe I'll just have to swear a lot and do it while its on the bike.. might be harder but at least I'll stay OTR :P I do like taking things apart though.... |
#58 | |
#59 |
glad to be of service. Its an odd thing to use, and a faff, but it works to some degree. Suppose it depends on how mucky it was in the first place. Oh and I found it eats the corrosion off polished rims, but you have to be careful with it, followed by brasso wadding
#60 | |
The front washer is a right bugger to get out, and you stand a fair chance of damaging something, so you might as well leave it in. Unless the washer is actually disturbed then there's nothing to distort on fitting, so leave it alone. If in doubt use a smear of exhaust sealant.
Dennis Brown | Dappa D | Idle Banter | 3 | 21-11-08 01:33 PM |
A letter to Mr G Brown | gettin2dizzy | Idle Banter | 5 | 17-04-08 07:00 AM |
Brown trouser moment? | lukemillar | Bikes - Talk & Issues | 2 | 30-03-08 08:13 AM |
Dan Brown Books | gettin2dizzy | Idle Banter | 15 | 24-10-07 01:29 PM |
Cameron Vs Blair/Brown | rob13 | Idle Banter | 17 | 07-12-05 11:41 AM |
