Old 20-06-09, 02:35 PM   #51
flymo
flymo's Avatar
Default Re: Project - Snail
Yeah mate, it was running fine when he give it me last week.
Ok, see no reason then why it shouldnt turn the motor over with the starter. It might not start but thats the ignition system, seperate to the starter.
Just a little puzzled, you mentioned that the engine seemed to lock, or at least not turn over. May be that the starter itself has a fault.
Old 20-06-09, 02:53 PM   #52
plowsie
But like I said, I tested 2 starters out of the engine and they spin fine with power from other bikes battery.
Old 20-06-09, 05:24 PM   #53
mister c
mister c's Avatar
Stu, just a thought, have you had the plugs out, or dropped the oil since you took it from here?
I am just wondering if it may be "hydrauliced" because it was on it's side when we put it in the car. Could be worth whipping the plugs out & manually turn the engine over with a socket on the end of the crank just to see if any oil has made it's way into the barrels. Tis just a thought. The engine was turning over fine, so I cant see as it's something on the motor itself.
Old 21-06-09, 02:12 PM   #54
plowsie
Had socket on end of crank just now, not budging, broke a ratchet trying, it turns slightly but not very far and not free at all
Old 21-06-09, 02:21 PM   #55
mister c
mister c's Avatar
Have you had the spark plugs out & tried it?, if so, it totally amazes me, it was running the day before.
Old 21-06-09, 02:41 PM   #56
plowsie
Yep plugs are out. Is there any chance oil could have got into the head and caused a vaccuum type effect? but then that raises the question, why would that stop it from turning?
Old 22-06-09, 08:13 AM   #57
Hydraulic lock.
Old 22-06-09, 08:31 AM   #58
flymo
flymo's Avatar
Hydraulic lock.
Would have expected the motor to turn via a socket on the crank Chris with the plugs removed.
Old 22-06-09, 08:58 AM   #59
plowsie
I drained the oil yesterday, would that not have cleared the hydrolock? Or is it a remove the head jobbie?
I tell you what, I officially hate engines!
Old 22-06-09, 09:01 AM   #60
plowsie
Not if it is locked via more than one piston maybe?
help with uni project TeddyBearKing Idle Banter 20 17-04-09 06:33 PM
H*nd* project DavieSV Photos 0 07-02-08 11:11 PM
Londons Fastest Snail scorpion Bikes - Talk & Issues 7 14-05-07 06:12 PM
snail trails poisonidea Idle Banter 16 07-01-07 11:21 AM
What 'project' for £100 glade Bikes - Talk & Issues 20 24-10-06 07:19 PM
