Old 22-10-09, 11:54 PM   #51
skeetly
skeetly's Avatar
Default Re: Underfloor heating, any plumbers?
yup will kill it dead. Seems strange I know when it has a 6" hole in the top but it does work
Get the fire cement out and chase the joints, you might be surprised
skeetly is offline   Reply With Quote
Old 22-10-09, 11:57 PM   #52
Luckypants
Luckypants's Avatar
Originally Posted by skeetly View Post
Ours is a 3" metal disc on a thread so you can 'spin' it in and out.
a 1/16th gap to keep the thing over night and 3/8th to have it roaring.
Thats how fine the control is. Tiny leaks make a massive difference
got to agree with Skeetly there, the air control on mine is thermostatic, but the amount of movement on a 2" disc is 5mm from fully open to fully closed. if not properly sealed the fire never 'slumbers'.
Old 23-10-09, 12:03 AM   #53
Ours will not, with the door shut and the draught "fully closed" it still roars like mad.
I don't think the ash box is actually sealed onto the base of the stove. Bloody folks buying cheap shoite. "I warned ye!"
Old 23-10-09, 12:06 AM   #54
skeetly
skeetly's Avatar
Big leak somewhere then. You should be able to find it if you get it roaring...
Old 23-10-09, 12:08 AM   #55
skeetly
skeetly's Avatar
Relatively speaking that is, could be quite a small opening or lots of them.........
Old 23-10-09, 08:42 AM   #56
Luckypants
Luckypants's Avatar
Does the fire 'roar' with only coal on it even with everything closed? If it does then that suggests a leak underneath as coal fires need air from below to burn well.
Old 23-10-09, 12:50 PM   #57
Roars with anything on it if you close the door.
I think it is the tray underneath for the ash box as well as the flap at the back which is supposed to close the airflow off.
Old 23-10-09, 01:07 PM   #58
Luckypants
Luckypants's Avatar
definitely has a leak below. I'll demonstrate on mine the effect of leaving the ash pan door open, it will kettle within a few minutes and I have no doubt there would be explosive steam after 10 or 20 minutes.
You will have to control the rate of burn before fitting a boiler.
Old 23-10-09, 09:57 PM   #59
phil24_7
I have killed *all* the draughts and dry lined the external stone walls though; this made a huge difference.
What dry lining did you use and what steps did you take to remove the draughts?
Old 23-10-09, 10:18 PM   #60
skeetly
skeetly's Avatar
Cottage got gutted when I bought it. New wooden windows and doors with proper compressible seals. New floors (gutted I didn't put ufh in them )
Originally I left the walls unlined but stone walls have the same insulating value as an inch of polystyrene so Ilined them with insulated plasterboard and it's been much better New extension each end helped as well....
You need to make sure that your walls aren't damp and that you have a vapour barrier to stop any moisture withing the house condensing on the walls behind the boards or you will have hassle.
Easy. For a builder.......
.Org Plumbers? Dave20046 Idle Banter 213 09-04-12 08:51 PM
Any Plumbers in the house??? DF! Idle Banter 3 02-12-08 09:58 PM
Underfloor Heating Gazza77 Idle Banter 9 10-06-08 08:17 AM
Any plumbers on here? ukgooner Idle Banter 15 27-04-08 11:50 AM
Plumbers help with my new bathroom furrybean Idle Banter 27 06-02-07 09:23 PM
