Old 05-10-10, 04:08 PM   #51
benji106
Default Re: Is all this about chains true?
Not so, if the gearing is different then the front sprocket to rear wheel ratio is different, thus the bike travels a differing distance relative to sprocket rotation, so the speedo reading will be different.
Of course most speedos over-read a bit, were you to change the gearing in the appropriate direction the speedo may become more accurate.
Im confused, I thought that the speedo sensor was on the front wheel, so given the diameter of the front wheel is not changing how does the size/rotation of the sprocket affect it?
Old 05-10-10, 04:25 PM   #52
He's got an R6 not an SV650
Is this true? Jamie_SV Idle Banter 2 17-07-08 12:53 PM
Sad but true. tigersaw Idle Banter 20 10-07-07 01:17 AM
Nah It can't be true !! Blue Flame Idle Banter 12 28-06-07 12:18 PM
Is it true Ed Idle Banter 17 16-07-06 09:42 PM
Say it's not true!!!!!!!!!!!! Jester666 Idle Banter 11 15-07-06 02:34 PM
