#51 |
Don't even try, there'll be even less material to grip. Get the gripping stud extractor that you earlier mentioned and try that. A bit of heat and a sharp tap with a hammer and drift won't go amiss either.
#52 |
It will just muller the end and you don't have enough length to waste on that.
If socket stud extractor doesn't work fire in with the welder.
#53 |
Different on curvy, I used a little die grinder to split the nuts then I could attack the studs easily.
#54 |
ok cheers
Exhaust Security Bolts | xXBADGERXx | Bikes - Talk & Issues | 33 | 13-01-09 06:23 PM |
Removing bolts | pben47 | SV Talk, Tuning & Tweaking | 13 | 30-07-08 04:16 PM |
Removing Exhaust a Stud | Grinch | SV Talk, Tuning & Tweaking | 50 | 28-02-08 11:08 PM |
Removing the baffle - fuel exhaust | Ollie_07 | SV Talk, Tuning & Tweaking | 19 | 22-09-07 10:25 AM |
Exhaust Bolts Undone | TSM | SV Talk, Tuning & Tweaking | 4 | 23-11-06 12:51 PM |
