Closed Thread
Old 25-01-12, 09:42 PM   #51
-Ralph-
Default Re: GM V T-Shirts
Yep, Dizzy is the winner so far IMO
Old 25-01-12, 10:12 PM   #52
TamSV
TamSV's Avatar
Nice development on the theme that.
Should be a Belted Galloway though. That looks like a Holstein you've got there.
TamSV is offline
Old 25-01-12, 10:32 PM   #53
missyburd
Yep should be a Belted, but harder to make obvious with the cow at that angle, could fashion a back end in to fit the "belt" in. And date is 6-8 July.
Good team effort this is turning out to be all!
Old 25-01-12, 11:21 PM   #54
sputnik
Yup, it's surely got to be a belted Galloway.
And I like the bike/coo hybrid, but the problem is...
(and I really do apologise for these) should it be curvy or should it be pointy??
Old 25-01-12, 11:34 PM   #55
-Ralph-
You should be able to order your choice
Old 26-01-12, 12:02 AM   #56
missyburd
My turn to fiddle Just the idea you understand.
Old 26-01-12, 12:24 AM   #57
Reeder
Kinda looks like more of a ram than a cow
Old 26-01-12, 02:36 AM   #58
-Ralph-
That cows a bit silly. When I ride a motorbike I steer by holding onto the handlebars
Old 26-01-12, 08:09 AM   #59
Yes it is! The design has the cow as part of the bike, its horns ARE the handlebars.
Maria, the reason I gave alternative ideas to prompt imagination, is because the Belted Galloway cow is the most uninspirational animal to work with as far as tshirt design is concerned.
The problem you have is its natural 'block colour' markings. Traditionally our tshirts are on a black or a white background, when you put a Galoway on it, its looks naff, because of the naff block colouring....pooor cow You can only really use the cow on a white shirt, because if put on a black one, all you will see is a white strip....and no cow!!
Sometimes, you have to think out of the box, and as there are no stringent rules for the GM shirts....apart from it needs to have certain words, and be easy for a print shop to work with.
There will be no back end on my design, as much as I worked on it, it didn't suit, nor looked correct. I gave a cowbike, one which can be used on a black or a white tshirt, with not a lot of fuss as far as printing is concerned. If I wanted someone to fiddle I would have asked for it(and given permission as per KGs rules).......which is why I didn't fiddle with yours
I will correct the date.....I burgered up that one for some reason
As you can see with a simple negative flip, the design I have done can be easily rendered on a shirt, with a few tweeks to fill in certain areas in white, to mirror those parts in black on a white shirt.
dizzyblonde is offline
Old 26-01-12, 09:27 AM   #60
missyburd
Feck it, was only a suggestion, I was seeing what it looked like in belted cow colours, not stealing your idea and submitting it as my own
Closed Thread
S&WS T-Shirts? RichT South & West Surfers 104 16-06-09 09:46 AM
t-shirts apoc76 Idle Banter 2 08-01-70 03:52 PM
