Old 02-06-15, 09:39 PM   #51
Nick8529
Default Re: Charging Issues
No. I recently fitted a USB charging point and the plug in point for the oximiser so I've taken them off hoping it was them causing the issues but no luck.
I've ordered a new reg/rec now so fingers crossed that will finally sort it out
Old 02-06-15, 09:43 PM   #52
have you taken the bike for a run to see if its holding a charge or have you just tested the voltages?
Old 02-06-15, 09:46 PM   #53
Nick8529
No but I've charged the battery and left it for a day and it's been the same voltage. It also took a few times starting it where it sounds like the batteries dying before it completely went. And I've also tried it with a brand new battery
Old 03-06-15, 05:52 AM   #54
millemille
If it's a cheap ebay USB charging point, like the one I fitted recently, that uses a ****ty linear regulator to step down from the 12V of the battery, it could easily burn 30mA just doing nothing if you've not wired it to a switched supply that's only live when the ignition is on.
The one I fitted drained a healthy battery in 4 days...
millemille is offline   Reply With Quote
Old 03-06-15, 07:43 AM   #55
Nick8529
It's got a switch built into it and that was off. I've also taken it off completely but the voltages are still low
Old 05-06-15, 06:53 AM   #56
Nick8529
I've replaced the reg/rec and the voltages are up to 13.88v. Just in time for me going away tonight
Old 05-06-15, 06:56 AM   #57
Geodude
Geodude's Avatar
Glad you got it sorted enjoy your trip.
Old 05-06-15, 02:44 PM   #58
nutzboutbikes
That's good news buddy enjoy the TT.
Old 28-06-15, 07:37 AM   #59
Geodude
Geodude's Avatar
Did you make it there and back okay?
Old 30-06-15, 07:47 PM   #60
Nick8529
Yea luckily it all went fine and didnt have a single bit of bother. I took the jump leads just in case tho
Charging issues. farquare SV Talk, Tuning & Tweaking 6 30-04-12 08:46 PM
Car - battery/charging issues - any ideas? SV650S_DUB Idle Banter 3 27-01-10 10:07 AM
Handy link for people with Charging/Electrical issues xXBADGERXx SV Talk, Tuning & Tweaking 7 23-01-10 08:29 AM
The sources of my woes (charging issues and more!) thedonal SV Talk, Tuning & Tweaking 22 25-09-08 08:18 PM
Over charging Tris SV Talk, Tuning & Tweaking 8 21-02-06 12:13 PM
