Old 03-06-06, 05:53 PM   #51
morphout
Default tps
just did the mod today and i can say it is noticeably, although not significantly, smoother at low speeds. Probably enough to make for an easier traffic jam commute. Had a problem where the bike wouldnt even run for a minute, shut everything off and pulled out my connector wire, started it up and ran fine. So eventually, i got it tweaked and the line moves somewhere around 1470 (down from originally about 4k) rpm.
At first i thought i'd never get close to 1500 rpm, but tightened the torx enough that i could tap the TPS with a screwdriver and move it in the smallest increments. Did it twice before i hit 1470(ish)
Old 05-06-06, 09:57 PM   #52
wardy2602
Default tps
Hi all
Did this mod last week found two up riding near impossible in town before the mod my little baby was so jerky especially round mini round abouts.
Had no probs and what a difference its so much better now, I adjusted my idle down first from 1800 to 1200 and then the tps sensor down from 3500 to 1500 its much much better.
Didnt have a problem with the bolts either bought one of these very useful
http://www.maplin.co.uk/Module.aspx?...rivers&doy=5m6
Cheers lads for a great guide id recommend everybody to do it.
Old 14-06-06, 07:50 AM   #53
graphikill
okay so i tried this mod last night and founbd taht i must be the only person on this forum who has there idle set correctly and there tps correct...
went through the mod with my bro-inlaw and as we turned it on we found it to be exactly spot on....
maybe the lads at esb check for this when pdi'ing it or servicing it....
but what i did find is that there was some play in the throttle cables, now that they are adjusted they have made a hell of a difference...
a lot smoother in low gears and more responsive to boot
Old 16-07-06, 08:14 PM   #54
dotted
Just did the TPS mod , it was impossible to set it for 1500rpm's , 1900 rpm's was closest i could get , before it was at 3600 !
There is a real improvement at low speed / low rpm !
In the small 1 hour test ride i did, many times i found found myself holding tight to the handle bars waiting for the engine to kick back , but for my surprise it was just smooth
Great guide , thank you
Old 07-10-06, 11:10 PM   #55
MikeVStrom
Default TPS Tweak
Great tweak! My VStrom was quite a handful at low speed, but now it's smooth as silk. Well done coombest! By the way, on the Vstrom the clock becomes the meter. other than that it is just the same.
Old 24-10-06, 10:26 PM   #56
CortezTheKiller
Hi guys,
I've read all of this thread with great interest because in the 4 weeks that I've had my SV650K6 my only niggle has been the on/off nature of the throttle, which, I hadn't really realised consciously until I read these posts, only really appears at low speed.
Now I am a complete newbie. This is my first bike since passing my test 6 weeks ago and I know nothing about the mechanics of bikes. All I wanted to ask is, as my bike is going in for its 600 mile service on Friday, will the TPS and idle speed be checked and reset to the suggested values automatically, or should I ask the mechanics to take a look at them?
And as someone intimated earlier, does the engine breaking effect really decrease after this mod has been done?
I'm loving the bike by the way. The weather has been pretty good and I've done 700 miles in 4 weeks. I'm glad I chose an SV rather than an ER6-n.
Old 24-10-06, 10:53 PM   #57
Mr Toad
It should be done as part of the service, but no harm in asking. Technically I don't actually think it's a mod, more of an adjustment that sometimes has to be made from time to time, bit like adjusting your chain if it's become slack
Old 24-10-06, 11:04 PM   #58
Stu
Trinity
Stu's Avatar
I beg to differ. I adjusted mine straight after my 7500 service. Didn't think it was a service item so wasn't upset it wasn't done. but a pm to SV650Racer might give you a definitive answer.
Old 05-02-07, 08:48 PM   #59
janbros
Hi guys,
I'm new to this forum
I haven 't got an SV, just the 650 engine that I'm putting in to the frame of a Kawasaki KR-1S .
I wanted to start it for the first time yesterday, but couldn't 'cause there is something wrong with the injection, and I need to get into the dealer mode, and by googeling I ended up here.
my only problem is that my connector is broken where the dealer switch goes into, so can somebody please tell me the colors of the wires I have to connect ?
TNX
Old 05-02-07, 09:09 PM   #60
mattSV
mattSV's Avatar
Originally Posted by janbros
Hi guys,
TNX
Welcome to the site
Hmm - a 650 engine in one of the best handling frames - that could be interesting
No idea which wires to connect, however it might be worth starting a new post with the title 'Dealer Mode - which wires to connect?' just so it is more visible.
Good luck with the project and keep us updated.
Matt
2000 - 2004 SV650S
2004 - 2009 SV1000S
step bump hang man Idle Banter 3 12-10-08 04:53 PM
Trying to be green - a step too far Ed Idle Banter 2 02-06-08 11:21 PM
sv650 to a fz1 is it to big of a step up jans1971 Bikes - Talk & Issues 30 28-11-07 02:44 PM
Big Brother's next step? jonboy Idle Banter 5 20-03-06 03:42 PM
What's the next step? MaxSuzuki SV Talk, Tuning & Tweaking 9 10-07-03 10:48 AM
