Old 09-01-16, 07:09 PM   #631
TheWeeSteev
Default Re: What have you tinkered with today?
I ordered in a new set of bulbs, went with the Night Breakers as I'd read they were quite good. They arrived today but I was busy cleaning out my garage and fitting one of those Tutoro chain oilers, seems to be on right but I managed to get distracted while getting the oil through the hosing and now I have a lovely puddle of greenish chain lube on my garage floor
Will test out the system tomorrow, too much to do in the house tonight. Will switch the bulbs the morn as well and that should be me for a while.
Oh and I switched over my passenger LH foot rest as my own had been bashed in a fall, it's still not great though as the bracket is bent in slightly as well and I've no way of bending it back. Still my wee girl can still put her foot on it so that's enough for me.
Old 09-01-16, 10:35 PM   #632
adamdaniels
Seat cowl and headlight covers today
Good clean and front indicators weather permitting tomorrow!
Old 09-01-16, 10:55 PM   #633
DomP
Took apart the rear shock linkage and cleaned and greased the bearings. Quite clean and rust free. Swingarm bearings next when I can decide how to get many bike from the abba stand to axle stands.
DomP is offline   Reply With Quote
Old 10-01-16, 11:20 AM   #634
punyXpress
punyXpress's Avatar
When you remove the swinging arm bearings, what's going to hold the whole kit & caboodle off the floor?
Now: Street Triple R
Old 10-01-16, 11:25 AM   #635
gibbzy2k1
Fitted a temporary fender extender. Doesn't look pretty but hopefully it's only for a week.
Sent from my D5503 using Tapatalk
Old 10-01-16, 12:16 PM   #636
adamdaniels
Nice clean, some chain wax and discovered some snapped fairing that was fixed with glue...
Old 10-01-16, 12:23 PM   #637
Buy the Abba stand kit that uses the footrest instead of the swingarm pivot. Its specifically designed to do swingarm bearing changes. Same price as the adaptors for each bike, and can be left in place
Old 10-01-16, 05:49 PM   #638
RPM
Adjusted clutch because bike was creeping forward at high revs with clutch in when waiting at lights.
Still does it after the asjustment (yes the full by the book one).
No cable adjustment left though so may try a new cable and old change before worrying about clutch plates
Old 10-01-16, 05:50 PM   #639
DomP
I think I will have to, considering the axle stands and flipped pegs method but worried they won't take the weight.
Old 10-01-16, 07:14 PM   #640
ophic
ophic's Avatar
Most likely the clutch lifter mechanism worn. Cables don't stretch nearly as much as that part wears.
Silver SV650SK3, Fuel exhaust
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
