Old 23-11-18, 07:04 PM   #6641
Default Re: Gripe of the day - What is yours?
Never ever use an Easy Out. That will be a ******* to remove, sorry to say I don't think you'll drill it out. It might have to be spark erroded out, which means the head has to come off. Sorry
Sent from my Lenovo TB2-X30F using Tapatalk
Old 23-11-18, 07:06 PM   #6642
those extractors should be banned. they dont work.
only suggestion i can make is to drill into the sides of the extractor using thin bits then try and remove the extractor stud. or cut a slot in the extractor stud and use an impact and flat bit to turn it back out i would personally go with the flat bit.
there are bits that drill into extractors no problem but they cost lodsa dosh. ALWAYS USE CUTTING FLUID DESIGNED FOR THE METAL YOU ARE CUTTING.
there are mobile stud extractor companies out there. you could try giving one of them a phone?
Old 23-11-18, 07:13 PM   #6643
Adam
Obviously this guy is too far away from you, but I've seen him post some great repairs on broken studs etc, so as Bib suggested find one in your area
https://www.threadworx.co.uk
Old 23-11-18, 07:14 PM   #6644
Oh and throw them Easy Outs away
Old 23-11-18, 07:15 PM   #6645
SV650rules
It helps if you can get area hot before trying to extract the bolt as the aluminium expands more than the steel of the bolt and slackens its grip on the thread a bit.
As Bibio says if you can safely get a cutting disc in there and cut a slot, worth a try. I have used extractors before but always get the aluminium hot.
2016 SV650 AL7
Old 23-11-18, 07:38 PM   #6646
Adam Ef
Adam Ef's Avatar
It was all as hot as I could get it. Can't run the engine with the exhaust off and an hour of drilling and it cooled down. Going to have a rest and a think. Fed up with it all now.
Cheers for advice though everyone.
Old 23-11-18, 09:55 PM   #6647
Aye, best to have a rest when this happens, clears the mind
Old 23-11-18, 10:37 PM   #6648
Heorot
Tonight on my way home I had a blowout doing 70 on a dual carriageway but didn't realise until the ride became rough. There was no change in the way the car handled but I was near my exit so continued until I came off and found a safe place to park. The front nearside tyre was completely missing and I realised that for the last quarter mile I was driving on the rim, hence the vibration.
Needless to say, the space saver was under inflated at about 20psi but I put it on anyway after half an hour struggle to jack up the car. Fortunately I was only a couple of hundred yards from a Tesco garage so I was able to put the full 60psi in it. So new tyre and probably a new alloy too, if I can find one for a 12 year old WRX.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 23-11-18, 10:43 PM   #6649
Chris_SVS
Chris_SVS's Avatar
Non forecasted rain. Out for a cycle this morning and ended up absolutely drenched
Chris_SVS is offline   Reply With Quote
Old 23-11-18, 10:44 PM   #6650
shiftin_gear98
shiftin_gear98's Avatar
Dentist.
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
