#6951 |
I actually found a 5th OM10 but sadly it was too far gone to save. It has been stripped of its useful screws and prism.
#6952 |
Finally got some good measurements on the Super Fujica, I think it needs a 0.9mm shim behind the shutter. Kenzie, is it possible to print something to an accurate thickness like that?
#6953 |
The printer I think can print at 0.2mm layer thickness . I just need to sort the print bed calibration out and probably change the filament (been having trouble with the black PLA currently loaded) If you have dimensions I could possibly whip something up.
Sent from my Xperia using Tapatalk
#6954 |
John T
This might be of interest to you chaps.tomorrow night bbc2 10.30pm
![]() Sent from my Moto G (5) using Tapatalk
Admin for this forum and the main site. John@sv650.org Last edited by admin; 01-05-20 at 08:41 AM. |
#6955 |
Cool, will have to take a look. Been binge watching season one of Lost. Didn't see it tbe first time and its on Prime. Managed to watch half of them yesterday.
#6956 |
Johnny, what are the likey issues I'm likely to encounter with an Olympus 35 LC?
#6957 |
Umm, plague, famine... I don't know! Looks like the CdS version of the Auto S I have, and from what I read just now, no auto functions, which is sometimes a blessing. I've found Japanese 35mm cameras tend to work better than European ones of the same age. My Auto S is indefinable lovely to use and to see the pictures. (FWIW it's not auto at all, just centre-the-needle metering, which was the nearest thing back then, and better than match-needle.)
I'll have a look at what size spacer I'd need. When you say 0.2mm minimum, I presume you can print in layers of different thicknesses, or would i have to choose 0.8mm or 1.0mm? |
#6958 |
Ah, I thought you had an LC. I just picked one up from eBay and its got a broken self timer lever, and shutter not working. Hopefully it will just be a case of the self timer is set and it needs some assistance to complete its cycle. Minimum it will print I think is 0.1mm. I just need to get it set up again. Need some stick glue to help it stick to the bed. I could print various sizes so you can mix and match?
#6959 |
That would be great in fact, I took two measurements, one about 0.85mm and one about 0.94mm. It wasn't easy to do so I'm going for 0.9mm at a guess and leave the rest to DoF and/or RF adjustment! So yes, some different pieces to mix and match would be ideal.
#6960 |
So what inner/outer diameter do you need?
