Old 03-02-17, 07:40 AM   #61
SheepShagger
Default Re: Lightened Flywheels - curvy and pointy
FFS, i missed this, typical.
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 03-02-17, 11:37 AM   #62
millemille
I did PM you before xmas about the batch I was doing and whether you wanted in....
Anything more than a batch of 5 is worth my while doing, so if you want yours doing you can either wait until 4 more need doing or you can see if you can round any more up yourself.
millemille is offline   Reply With Quote
Old 03-02-17, 12:57 PM   #63
DomP
Default Re: Curvy lightened Flywheel assembly
On a pointy what extra bhp can be expected and how much does it alter the characteristics of the engine?
DomP is offline   Reply With Quote
Old 03-02-17, 01:41 PM   #64
millemille
Ok, a lightened flywheel doesn't - despite what some may tell you - result in any increase in power from the engine.You aren't improving gas flow through the engine or increasing the engine's capacity or reducing the drag of a part that runs in oil.
What the lightened flywheel does is reduce the rotational inertia - the engine's resistance to change in rpm - and gyroscopic inertia - the resistance of the flywheel to changes in angle of lean when spinning.
So the engine revs up and down more quickly - improving the throttle response and making engine braking/downshifting smoother and less likely to upset the back end/lock the back wheel.
The bike is quicker/easier to steer and lean. Imagine you're holding a spinning bicycle wheel by each end of the axle between your hands. Now imagine trying to twist the wheel, the gyroscopic inertia of the spinning wheel resists you trying to twist the wheel. Well the flywheel spins at engine rpm and we take between 300 and 800g from a flywheel (depending on model, number of magnets, steel or ti bolts etc) - so imagine how much easier it would be twist a bike wheel spinning at 10,000rpm if it were that much lighter...
It also gives the crank a much easier time; the inertia of the flywheel fights the crank trying to accelerate every time each cylinder fires. Now Suzuki very cleverly put an oilway (a hole) in the end of the crank shaft close to the keyway (slot) also in the end of the crankshaft and the SV crank has a reputation if fitted to a bike that is ridden hard for cracking between the oilway and keyway and failing catastrophically.....
Old 03-02-17, 04:55 PM   #65
DomP
Thanks for the detailed reply, now I feel like I need it doing having seen that crank.
Old 03-02-17, 05:39 PM   #66
millemille
I'll do another batch if there's enough interest. If Sheepshagger wants his and you want yours then there's 3 more, minimum, needed which shouldn't be too much bother to get together...
Old 03-02-17, 05:41 PM   #67
DomP
Was it £125 all in using my flywheel?
Old 03-02-17, 05:44 PM   #68
millemille
£145 now, sorry should have updated the original post.
Old 03-02-17, 05:45 PM   #69
SheepShagger
Count me in if more people want it done.
Old 03-02-17, 05:50 PM   #70
Nicky S
Nicky S's Avatar
I'm in
Is the naked and s fly wheel the same ??
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Lightened flywheel - cheap in exchange for testing... millemille SV Talk, Tuning & Tweaking 8 09-06-15 06:15 PM
Lightened flywheel - where? m1tch_1987 Bikes - Talk & Issues 4 21-10-13 05:45 PM
curvy starter assembly jimathyy Stuff Wanted 9 11-01-12 09:58 PM
Curvy right foot peg assembly wanted mike_red2uk Stuff Wanted 2 20-12-09 12:33 AM
Gel seat and underseat lock assembly for 99 curvy BrainsOnToast Stuff Wanted 3 23-08-07 07:54 AM
